Wheel bearing or something loose... - Suzuki Forums: Suzuki Forum Site
LinkBack Thread Tools
Old 03-11-2012, 06:48 PM
Zami is on a distinguished road
Default Wheel bearing or something loose...
I noticed today while I was cleaning and wiping off the Sami that the passenger side front wheel has a little play in it. If I grab the sides of the wheel and try to rock it back and forth the wheel actually has some play or slack in it. I checked the lug nuts and they are all tight. Any suggestions on what to look at next?
Thanks in advance!
[SIGPIC][/SIGPIC]87 stock with 2" Free Flow Magnaflow exhaust system. San Diego, CA.
Zami is offline   Quick reply to this message
Old 03-12-2012, 12:07 AM
I have taken 2 wheel drive hubs off the front and back of different vehicles. I have not taken the front hubs off a 4 wheel drive yet. Can I just unbolt and inspect? Any tips or things to look out for? Thanks!
Old 03-13-2012, 03:27 AM
johnfromperth is on a distinguished road
All front wheels have a little play in them. If you grab the wheel at 3 and 9 o'clock, the play you can feel is in the steering gear. To get a true feel of it, get someone to hold the steering wheel steady.
If you grab the wheel at the top, you can rock it in and out. That is play in the king pins.
A little play is normal in both directions. Unless there are some klonk-klonk noises don't wory about it. Go check some other vehicles to get a feel for what is normal. Remember bigger wheel diameters will make the movement much more obvious.
johnfromperth is offline   Quick reply to this message
Old 03-13-2012, 02:43 PM
Thanks John I will check it out. Always helps to get some insight.
Old 03-18-2012, 10:18 PM
I hope this rain stops soon then i can get back to seeing where exactly where this play is coming from. I went and purchased an Haynes manual for working on the Sami. Not sure if I will tackle taking the hubs off if it turns out to be a bearing or not.
Old 03-30-2012, 03:36 AM
chrisjarvis is on a distinguished road
People understandably get confused between wheel alignment and balancing. So what is wheel alignment? Wheel alignment is simply making sure that all four wheels are pointing in the right direction.
Reputation Management|Reputation Management Services|STC Technologies
chrisjarvis is offline   Quick reply to this message
Old 03-30-2012, 01:50 PM
I took my Sami by a mechanic shop this morning and asked for an estimate on whatever needed to be fixed on the front end. I am very happy with the results. The mechaic said the front end was actually pretty tight. He said the bearing might need a little tightening on the one wheel that has a very slight play in it, but not to worry he said its not going to hurt anything. I am going to order a set of front wheel bearings and seals to have on hand just in case.
Old 04-05-2012, 04:50 PM
chevy4x48586 is on a distinguished road
The front bearings are actually really easy to change. As are most things on the samurai i have found. Generaly play in the wheels side to side is a stering issue. IE tierods,steering gear box etc. If the wheel bearings are gone you can tell by grabbing the wheel at the top and trying to pull it towards yuo and push away. If it has a lot of play or makes a clunking sound you can be sure the bearings are toasted. If you do end up doing the job make sure to have rags for all the old grease, and new grease to put in the bearings etc.
chevy4x48586 is offline   Quick reply to this message
Old 04-05-2012, 06:53 PM
Thats what I mean, when I grab the tire at the top and rock it back and forth toward myself and away from myself their is a very small clunk, I would estimate the slack so to speak is 1/16 of an inch or so. I had a shop look at the steering and tie rods, he said it was surprizeing tight for that year, etc. So it must be the wheel bearing, and its not that bad to replace? Thanks.
