Oil pressure? - Suzuki Forums: Suzuki Forum Site
Old 10-01-2011, 12:20 AM   #1 (permalink)
Zami is on a distinguished road
Default Oil pressure?
I want to install a oil pressure gauge. Has anyone put one on? Does a universal oil pressure gauge work OK? Also I found a 87' Sami in a bone yard today and got a few parts off it I didn't have like front mud flaps, the shelf that goes under the glove compartment and an antenna. I am going back for more later.
87 stock with 2" Free Flow Magnaflow exhaust system. San Diego, CA.
Zami is offline   Reply With Quote Quick reply to this message
Old 10-01-2011, 08:56 AM   #2 (permalink)
Universal oil pressure gauges work fine - the challenge is getting them connected.
Most gauges are supplied with a 1/8" NPT adapter and Suzuki uses a 1/8" BSPT thread on their oil pressure sender, so an adapter is needed.
I would also suggest an electrical gauge rather than mechanical and that you use a T piece so that you can leave the low oil pressure switch connected - it's not a good idea to screw an adapter onto the block and then a T with the two senders into the adapter - the brass will fatigue & break because of the vibration, so you'll to mount the T & the senders somewhere rigid and connect it to the block with a flex.
Not the easiest of things to fit, but also not difficult - and in my opinion well worth it.
Old 10-01-2011, 10:40 AM   #3 (permalink)
Thanks for the great info. I wonder if my local auto parts store will have the adapter you mention? If their was a drop in oil pressure or just low for some reason I sure would want to know it, so leaving the low oil pressure switch will make the light come on right?
Old 10-05-2011, 06:02 AM   #4 (permalink)
Chrisjb330 is on a distinguished road
Iv got oil pressure, oil temp and water temp on mine, mounted in the centre of the dash. Let me know if a pic would help you. I used a universal one from ebay and got this;
MOCAL - EXTENSION BOLT 3/4UNF - M-EB-3/4UNF
Hope this helps, Chris
Chrisjb330 is offline   Reply With Quote Quick reply to this message
Old 10-05-2011, 07:38 AM   #5 (permalink)
ellsworth23 is on a distinguished road
Default Oil Pressure tap location on L20B
I have a 1986 Samurai in sorry shape with an L20B engine (Nissan) that I 'd like to put an electric oil pressure gauge in. Chris' suggestions on the taps and not using brass in the block are good ideas I hadn't considered.
My question on the L20B is where do I tap in for oil pressure? I'm looking to put in an electric coolant temp gauge also and can't figure out where to tap into for that either. I'm not much of a mechanic, although I do controls work for a living so I can manage the electrical / instrumentation part just fine. I'm just having trouble finding any info on the L20B and instrument connections.
A picture of your dash with the gauges would be nice. It sounds like what I plan to do.
Thanks, Paul
ellsworth23 is offline   Reply With Quote Quick reply to this message
Old 10-05-2011, 08:36 AM   #6 (permalink)
It might be a good idea to ask on a Nissan forum, for Nissan related information - but the normal place to fit an oil pressure gauge sender is in the low oil pressure switch port - unless you happen to know of an existing threaded hole that goes into the main oil galley.
Another place to do it is off the oil filter - you can fit a "sandwich" that goes between the filter and the mount that has the tappings for oil pressure & temperature gauges.
Installing a coolant temperature gauges is much more challenging - ideally you want it in the water outlet elbow, which is usually where the thermostat is. You'll see some folk fit it in the radiator top hose, where it does a half decent job - once the thermostat has opened and allowed coolant to circulate - the problem is that if the thermostat doesn't open, the engine will self destruct without the gauge moving from cold.
The answer to your questions however should come from someone familiar with the Nissan L20B - which I am not.
Old 10-05-2011, 11:22 AM   #7 (permalink)
Sorry, may not have been clear in what i ment. I have used a sandwhich plate inbetween the oil filter and engine block, i had to order the different size adaptor bolt as it didnt come with the kit. Simply get a universal temp/pressure reading 1/8th i think and plug in, or two for both. Really easy to do once you have the parts. Will get you that pic tomorrow
Chris
Old 10-05-2011, 03:02 PM   #8 (permalink)
I'll look into the sandwich idea. I tried a couple of Nissan forums last month. I had some views but no answers to questions so I tried this. You guys answered same day. I appreciate it. Thank you both.
Old 10-05-2011, 11:18 PM   #9 (permalink)
Yes, a pic would be great! Now you mention it the water temp would be nice to if its not to much of a hassle. Thanks.
Old 10-06-2011, 03:38 AM   #10 (permalink)
[IMG][/IMG]
