Detroit EZ Locker in Samurai - Suzuki Forums: Suzuki Forum Site
Old 07-16-2011, 07:08 PM   #1 (permalink)
racer37's Avatar
racer37 is on a distinguished road
Default Detroit EZ Locker in Samurai
I have got a detroit ez locker in the rear axle of my samurai that clanks every once in a while. I have 4.57 yukon gears in it and I would like to keep my gears but get rid of the locker. Can I easily take the locker out and put a spool in?
racer37 is offline   Reply With Quote Quick reply to this message
Old 07-16-2011, 08:23 PM   #2 (permalink)
weldboy is on a distinguished road
Default Mini Spool
Yes, When you take the EZ locker out the mini spool will replace it.
weldboy is offline   Reply With Quote Quick reply to this message
Old 07-16-2011, 09:06 PM   #3 (permalink)
VaderSS's Avatar
Garage
Easy to replace the locker with a spool, but won't the gear lash have to be adjusted?
Wayne Bengston
Old 07-17-2011, 01:17 AM   #4 (permalink)
Default Spool
Once you pull the 3rd member out count the number of turns on the adjustment, then install the spool and put the adjustment back the same amount of turns and your good to go.
Old 07-17-2011, 09:50 PM   #5 (permalink)
Ok, yes, it is an easy swap.
But are you looking to make a trail-only vehicle?
The EZ locker may have a few quirks (like an occasional popping), but it is still streetable. The spool will be maintenance free and great for the trail, but if you didn't like the popping on the street, the spool won't get you less attention when trying to turn a corner. Make sure you use a turn signal because the cops will be watching you closely as you squeal around each turn.
Bill
in old El Paso...
Old 07-19-2011, 11:23 AM   #6 (permalink)
Beerman is on a distinguished road
Default E-Z Locker or Lock-Rite?
Which do you prefer?
I intend on installing on front diff so not to be in use unless we are off-road and have the hubs engaged. The "popping" will for sure remind me to disengage the hubs
No real rock climbing, just snow in the winter and the beach otherwise.
The only time I have been stuck was a freeking cross-pile of snow at an intersection the grader left. If the front wheels were locked probably could have climbed thru it
Thanks!
87 Sammy, Stock 1300, Stock Carb with Vent Tube,Pacesetter Headers, 2" exhaust, no-cat, 33s on Shackle Lift. EZ-Lockers up front.
Beerman is offline   Reply With Quote Quick reply to this message
Old 07-19-2011, 01:13 PM   #7 (permalink)
Thanks!
Both automatic lockers are almost identical (almost) but they are pretty much equal in reaction and strength. I started with my first (lockright) locker in the front axle. It was for the same reason you mentioned. Just remember to lock the hubs BEFORE heading into the slush and mud.
Bill
in old El Paso...
Old 07-19-2011, 02:33 PM   #8 (permalink)
racer37's Avatar
Can I take the 3rd member from the rear that has the locker in it and put the whole 3rd member in the front axle or is it different?
Old 07-19-2011, 02:59 PM   #9 (permalink)
Yes, but with a qualifier... see *26 spline front axle upgrade.
The axle shafts are different sizes. 22 spline in front and 26 spline in the rear.
The early sammy's had identical front and rear differentials with the only difference being the sidegears that the shafts slide into, so you could swap diff carriers with only a sidegear swap.
Changing stock sidegears
In the later years the front differential changed to a weaker (known as 2 pin) carrier. I would not suggest putting a 2 pin carrier in the rear although it would be physically possible.
*You can now purchase stronger replacement front axles that are built with 26 splines that will allow you to swap back and forth (front to rear and back) without changing gears.
Bill
in old El Paso...
Old 07-20-2011, 02:24 PM   #10 (permalink)
Default Lock Right 1510
From what I read I need this model in 87 Sammy, front diff. Shopping I see sets on Ebay with 2 plates, some washers and pins, but on Amazon there is an extra middle casting? all a little over 200 bucks
Tried to cut and paste photos with no success...
Dazed and confused!
