Temp Sensor Diagnosis - Suzuki Forums: Suzuki Forum Site
Old 07-12-2011, 09:34 AM   #1 (permalink)
Beerman is on a distinguished road
Default Temp Sensor Diagnosis
87, 1.3 with 2-wire sensor at block/t-stat. Any way to ohm it out? Had to re-solder and heat shrink tubing on it a year ago and worked all winter. Gauge reads cold all the time, even at 109! Rest of gauge cluster works.
Where can I get a factory replacment if needed?
Thanks!
87 Sammy, Stock 1300, Stock Carb with Vent Tube,Pacesetter Headers, 2" exhaust, no-cat, 33s on Shackle Lift. EZ-Lockers up front.
Beerman is offline   Reply With Quote Quick reply to this message
Old 07-12-2011, 11:58 AM   #2 (permalink)
Default Asked and Answered
Found my thumb drive with FSM and I was looking at wrong sensor
Will take it from there !
Old 07-12-2011, 12:13 PM   #3 (permalink)
Yup - the gauge is a single wire sensor - connect a low wattage 12V lamp (5W license plate or similar) between the sender lead & the block, turn the ignition on and see if the gauge moves from cold - if it does replace the sensor, if it doesn't check for a broken wire.
