Dang weber!!! - Suzuki Forums: Suzuki Forum Site
Old 07-11-2011, 08:07 AM   #1 (permalink)
KJ2837 is on a distinguished road
Default Dang weber!!!
My throtle is still sticking!! I have battled this ever since I put it on about 3 yrs ago!! It will not go back to idle it sticks and races even after installing a return spring???I am so fed up with this thing! Plus its killing my drive train because my engine is racing and when I let out on the clutch it snatching my shafts! Any ideas?? Are the harley carbs better as far as the throtle issues??I dont have the $$ for that set up right now but this weber must go!!
KJ2837 is offline   Reply With Quote Quick reply to this message
Old 07-11-2011, 01:09 PM   #2 (permalink)
hotrodsami's Avatar
My weber never had this problem. Things that will make a weber stick open are the same things that will make any other carb to stick.
make sure the return springs (on the carb and on the pedal in the cab) are in the right place. Make sure the throttle cable is not binding up and properly adjusted. you can try spraying some lub on the linkages and see if that helps.
Weber has been making high performance carbs for years and is still seen as one of the best carbs you can get for many foreign vehicles. Keep the carb you have and work out the kinks and it will do just fine
[FONT="Comic Sans MS"][SIZE="3"]Failure is [U][I][SIZE="4"]always[/SIZE][/I][/U] an option[/SIZE][/FONT]
hotrodsami is offline   Reply With Quote Quick reply to this message
Old 07-11-2011, 01:26 PM   #3 (permalink)
Ive done all of that...New cable,lubed it,adjusted everything many many times,and put my own return spring on and all of that still hasnt worked?I can raise the hood with the engine racing and push the throtle over to where its suppose to rest and it goes back to idle but it just wont go back to idle by itself?Its not the cable because its loose when its racing and I have to push the linkage over with my finger on the carb to get it back to idle?? Am I missing something????I have been fighting this for 3 yrs and Im just fed up!!! Plus it embarrassing to pull up to a red light and when i push in the clutch it sounds like im about to take flight.....
Old 07-11-2011, 06:24 PM   #4 (permalink)
zooki4x4's Avatar
One thing that might have happened is that the nut holding on the throttle linkage to the shaft has been over tightened. Making it bind against the carb body. Back it off a little and use very little pressure to retighten this nut. The shaft might also be bent causing it to hang in a spot.
Old 07-12-2011, 03:31 PM   #5 (permalink)
Well,I kinda feel like an idiot....I ask one of the machanics at work and he asked If I had tried cleaning it with carb cleaner.I told him yes but its been a while and it did nothing at that time to fix it.He said since it had been on for 3 yrs...to remove the carb and clean the floats and everything else I could get to on the bottom...I did and as of now its running like a top....crazy its always the simpliest things that get ya....Thanks for the help and i will report if the problem returns..
Old 07-13-2011, 12:55 PM   #6 (permalink)
Ok,spoke too soon! I worked great for 1/2 a day then right back to the way it was?So why when I clean it it worked then back to the way it was????Im missing something?Nothing looks bent but maybe I cant tell??
Old 07-14-2011, 04:14 AM   #7 (permalink)
Garage
i had the same sort of problem when i put empi carb on and it was that the return spring needed to be adjusted to the right tension
Old 07-17-2011, 03:54 AM   #8 (permalink)
alternator's Avatar
Gallery: 4
Beats me. I had the problem but it was the throttle cable; replaced it with a new one and solved the problem.
Old 07-17-2011, 07:51 PM   #9 (permalink)
Garage
i done that as well forgot to put in my last post
Old 07-21-2011, 11:48 AM   #10 (permalink)
well,just an update...Still have the same problem?The only thing I havent done is just take the dang thing off and clean it underneath as well and maybe with it off I can see if something is binding.Its driving me nuts!! Ive go to figure this out....Thanks all of you guys for your imput! You never know what you may be missing unless you ask...
