Installed aftermarket tachometer - Suzuki Forums: Suzuki Forum Site
Old 03-28-2011, 09:05 PM   #1 (permalink)
SuzukiPilot is on a distinguished road
Default Installed aftermarket tachometer
Was pretty easy to install. Here is a photo. Got it from Amazon. Didn't like not knowing RPM. Also put in stereo. It had an old Ford radio casette player. Think it was as old as the Sammy.
Amazon.com: Sunpro CP7906 Mini Super Tachometer II - Black Dial: Automotive Amazon.com: Sunpro CP7906 Mini Super Tachometer II - Black Dial: Automotive
SuzukiPilot is offline   Reply With Quote Quick reply to this message
Old 03-28-2011, 09:36 PM   #2 (permalink)
OOOH I need one of those! It would match my clock, and I got an extra hole there to fill.
Old 03-28-2011, 10:06 PM   #3 (permalink)
Did you remove the vents to have extra holes?
Old 03-28-2011, 10:16 PM   #4 (permalink)
The center blank for the stock clock is just a gaping hole right now. I had a 4 inch diameter clock that was in that hole, but I bought a stock 3 inch clock and put it in one of the two center vent holes. I have a kill switch in the other one, but now that my battery drain issue has been resolved, i never use the kill switch anymore. I'd like to put something usefull in there. So if I put the tach in the kill switch vent hole, I'll just have the big center cutout to fill with something. Maybe I'll put a hamster ball in there.
Old 03-30-2011, 03:18 PM   #5 (permalink)
KJ2837 is on a distinguished road
Dang,wish I could do that!! I have the older dash with the square vents....Looks really cool though!!!!
KJ2837 is offline   Reply With Quote Quick reply to this message
Old 03-31-2011, 01:50 AM   #6 (permalink)
Gallery: 8
The NEWER dash with square vents can have a tach too.
SunPro 2 5/8" tach, in 2.5" hole. It's held in place using clear RTV on back of tach flange before insertion into dash.
Tip: Add a dab of RTV to the 4/6/8 cylinder switch (on the back) to hold it in position. It's easy enough to peel off and change, if you get a V8.
Edit: I connected the tach sense signal wire to the Br/W wire on the coil.
Old 03-31-2011, 03:46 PM   #7 (permalink)
Hey!!! Never thought of that...Thats cool!!
Old 04-30-2011, 06:19 PM   #8 (permalink)
parks1956 is on a distinguished road
where do you plug the tach wire into, would like to hook up a tach also , thanx to all who respond!!!
parks1956 is offline   Reply With Quote Quick reply to this message
Old 05-02-2011, 01:31 PM   #9 (permalink)
crispy is on a distinguished road
Damn, I was just thinking of ordering the exact same tach last night too...
crispy is offline   Reply With Quote Quick reply to this message
Old 05-02-2011, 01:57 PM   #10 (permalink)
Going from memory I think there are 4 wires. One goes to the coil, one to ground, one to switched power, and another for the light. The light wire should go to the same wire that powers the dash lights if you want it to dim with the dash when you turn the dimmer knob. I had a hard time finding that wire so I just hooked up the light wire to a switched power source. It works fine for me as at full brightness it is not any brighter than what I normally have my dash set at.
