Transfer Box noise - Suzuki Forums: Suzuki Forum Site
Old 03-10-2011, 07:22 AM   #1 (permalink)
Chrisjb330 is on a distinguished road
Default Transfer Box noise
Suzuki Samurai 1.3i 1994 - Bought before christmas and been trying to identify a noise since, it happens in all gears ( very slightly in lower ) when your at low revs ( under 2k ) and put your foot down, so that the engine is under load. Iv not been able to identify it until now, it sounds like its from the engine bay, but today i tried putting the transfer box in neutral and putting it through the gears. To my amazment it did it in all gears, it does it continuously in 5th gear at idle speed. Its like a rattling/vibration sound coming from the transfer box. Any ideas? Thanks in advance
Chrisjb330 is offline   Reply With Quote Quick reply to this message
Old 03-10-2011, 09:00 AM   #2 (permalink)
Check your u-joints. Sounds like it could be one of the joints in the jack shaft (intermediateshaft) that goes from the trans to the transfer case. Shut everything off and leave it in gear. Go up underneath. Grab that sucker and try to move/shake it violently. If it has any movement inthe joint then you need to replace the u-joint.
U-Joint Rebuild
Bill
in old El Paso...
Old 03-10-2011, 10:31 AM   #3 (permalink)
Will do anything else it could be?
Old 03-10-2011, 10:49 AM   #4 (permalink)
Just had a quick look at you cant move it in any direction except rotational (very slightly)
Old 03-10-2011, 12:23 PM   #5 (permalink)
The jack shaft is a good starting point, but continue out to the front and rear shafts. The whole shaft may rotate a little, but the joints need to be tight and movement-free.
It could also be the front output gear in the transfer case. Although the front driveshaft may not be turning as you test it, the friction may still be moving the gear enough to make noises as it catches inside. The front output gear has a strength issue.
Bill
in old El Paso...
Old 03-11-2011, 03:31 AM   #6 (permalink)
Iv asked one of my friends and they mentioned pinking? Where the spark ignites the fuel too soon? To be clear, Transfer case in neutral, gearbox in 5th at idle, this causes it to move and rattle enough so that you can hear it and feel it. Does it do it in anyone elses? Are these cars supposed to be ran at high revs? Thanks
