interior door trim removal - Suzuki Forums: Suzuki Forum Site
Old 02-08-2011, 10:53 AM   #1 (permalink)
millone is on a distinguished road
Default interior door trim removal
any help please on how to remove interior door trim on 07 Suzuki Jimny. thank you.
millone is offline   Reply With Quote Quick reply to this message
Old 02-08-2011, 04:01 PM   #2 (permalink)
HOARDER's Avatar
HOARDER is on a distinguished road
It pops on with push pin clips, you have to get a door panel remover tool, it shouldnt cost more than a few bucks.
1987 SAMURAI HARD TOP W/ PETROWORKS 40MM CV CARB!
HOARDER is offline   Reply With Quote Quick reply to this message
Old 02-08-2011, 06:30 PM   #3 (permalink)
Default interior trim removal
thank you for reply. ron
Old 02-08-2011, 10:28 PM   #4 (permalink)
SUZUKI NUT is on a distinguished road
Cool door panel
I used two thin putty knifes started at bottom corner slid one in between panel and door move til i found pin slide other one on other side till found pin pulled up on both it popped out it get easier as you go.
good luck.
SUZUKI NUT is offline   Reply With Quote Quick reply to this message
Old 02-09-2011, 04:06 PM   #5 (permalink)
Tuxblacray's Avatar
Tuxblacray is on a distinguished road
I used a 12' Standard screwdriver and a wonder bar (made by Stanley) using the same method outlined previously. The opening on the wonderbar straddles each side of the plastic male pin. It is also arched so that once inserted you push downward and it will pop the pin out without you having to pry outward on the panel at the same time.
I used the screwdriver to open the corner of the panel 1st and then slide the wonder bar in.
Any arched type tool would work well if positioned close to the pin. Long handled screwdriver style pry bar, pry bar, crating tool, wonder bar, etc.
Be careful to stay as close to the pin as possible so that you don't pull it through the door panel fiberboard.
If you happen to damage either the pin or the female door insert they sell them on Ebay relatively cheap.
Of course all of this is the cart before the horse.... Make sure you remove the screws and the trim around the inner door handle. You will also need to slide back the keeper spring and remove the window crank handle before any door panel removal can start.
I know the voices aren't real but some of them have pretty kewl ideas!
I get my Samurai Parts Here:
http://www.mikodaindustries.com/
Tux...
Tuxblacray is offline   Reply With Quote Quick reply to this message
