wanting to upgrade carby - Suzuki Forums: Suzuki Forum Site
Old 01-30-2011, 04:02 AM   #1 (permalink)
Garage
Default wanting to upgrade carby
ive been looking into upgrading my carby to a weber from standard the covert that i found in the states uses a 32/36 DGV weber ive been told by a carby specialist that the 32/36 is for a 2 liter engine. now the carby specialist i seen has a convert using a 32/34 DFT weber he said its made for a 1.3 liter engine he said that it doesn't have flooding problems like the 32/36 DGV. 32/34 DFT convert is $650 australian does anyone know about much about these carbys which convert would be better for a engine that has been bored out 20thou and has been port and polished balanced when built and has all raceing internals are these carbys trew webers or are they tthe fake ones
Old 01-31-2011, 10:02 AM   #2 (permalink)
HOARDER's Avatar
HOARDER is on a distinguished road
You need to look at the hd sd cv carbs from, petroworks.
1987 SAMURAI HARD TOP W/ PETROWORKS 40MM CV CARB!
HOARDER is offline   Reply With Quote Quick reply to this message
Old 01-31-2011, 10:29 AM   #3 (permalink)
getting parts and support for a harley davidson screaming eagle isn't going to be easy in australia though. There are other constant velocity side draft carbs though, and they are far superior for power gains than the weber down draft. Mikuni, solex, suzuki... they all make cv carbs that can be used with this engine. Weber also makes a side draft that won't flood on you. The only issue with the 32/36 flooding is when it's on a steep incline. I don't know that thge 32/34 wouldn't do the same thing. It's a shortcoming of the design of the float chamber, not the port size of the carb.
Old 02-01-2011, 02:30 AM   #4 (permalink)
Garage
when you say steep incline how much is a steep incline 75 degreese and greater? with doin side draft carb conversion i have'nt been able to find a manifold to suit. little help would be great?
Old 02-01-2011, 10:13 AM   #5 (permalink)
by steep incline I mean something that you won't find on-road anywhere. I can't put a number on it, but I'd say you'd have to be over 60 deg incline.
as for manifolds, the mikunis sell a manifold that bolts up to the samurai water jacketed intake. Petroworks and ZOR modify the stock intake to mount the cv carbs. You'd probably have to contact the manufacturer to get a manifold for the engine you want to run it on. Most of the distributors that don't normally deal with suzuki's won't have something like that in-stock.
Old 02-01-2011, 10:32 AM   #6 (permalink)
If you CAN find Harley parts though, you will never go back...
Bill
in old El Paso...
Old 02-02-2011, 02:29 AM   #7 (permalink)
Garage
so i looked at petroworks and theve got the manafolds thanks guys got a question now witch one would you go with the weber or the side draft?
Old 02-02-2011, 07:20 AM   #8 (permalink)
After running both, I would have to say the CV side draft hands down. No angle problems whatsoever!
Bill
in old El Paso...
Old 02-02-2011, 12:09 PM   #9 (permalink)
igaug is on a distinguished road
zuksoffroad.com also sells a very reputable cv carb kit. myside 1 and myside 2. one comes with an intake manifold and (myside 2) and the other adapts to your stocker i believe (myside 1). they use harley 40mm or 44mm cv carbs, but im sure you could adapt about any cv carb to it if you wanted to.
igaug is offline   Reply With Quote Quick reply to this message
Old 02-02-2011, 12:53 PM   #10 (permalink)
Myside 1 works well, but the improvement to Myside 2 straightened out the air flow and added some power. I have installed and tested both Myside 2 and the Petroworks systems with the 44mm HD CV carb. They both work well, but the Petroworks system was a cleaner install. Getting the full package from Petroworks includes a fuel regulator that is already set up for a perfect flow to feed the carb.
Bill
in old El Paso...
