need install guide for weber 32/36 - Suzuki Forums: Suzuki Forum Site
Old 01-23-2011, 07:20 PM   #1 (permalink)
SAMMYJAMMY is on a distinguished road
Default need install guide for weber 32/36
hey guys I just picked up a weber 32/36 dgav which should have a water choke but it does not, it does have a electric choke. All I need is the install guide for a weber to my 87 sammy. I picked up the carb for $80 with chrome air clear and filter, just need to get the adapter and guide thanks guys.
SAMMYJAMMY is offline   Reply With Quote Quick reply to this message
Old 01-23-2011, 09:52 PM   #2 (permalink)
Check out:
http://www.suzukiinfo.com/sierra/weber.zip
Bill
in old El Paso...
Old 01-24-2011, 12:26 AM   #3 (permalink)
Billjohn you rule
Old 01-24-2011, 08:59 AM   #4 (permalink)
Bazuki is on a distinguished road
Talking
I was unable to open Billjohns link but sounds like you got what you needed. I just swapped mine last week and still trying to get it dialed in. I found the adapter plates on ebay for 29.00 and already had the carb and linkage adapter. Basically everything comes off. All I still use is the vaccuum advance and when I get the fitting I'll connect the evap canister. I tapped power for the choke from the center slot on the yellow plug from the old carb.(I think) Easy enough to find with a volt meter. Noticeable improvement in the low end not as much at the top. New exhaust is probably next to get rid of the catalytic conv. that is probably getting plugged. Good luck with it. Dave
Bazuki is offline   Reply With Quote Quick reply to this message
Old 01-26-2011, 03:22 AM   #5 (permalink)
igaug is on a distinguished road
be sure and post results of exhaust please! i just installed a weber on mine last weekend. definate lmprovement from 1st through 3rd gear but not in 4th. i did notice it would take hills better at highway speeds in 4th though. im running 32 inch ssr's on a stock gears though so 5th is dead. im getting gears next month though with hopes to regain 5th.
did you port your intake when you installed the weber or just leave it in stock form?
igaug is offline   Reply With Quote Quick reply to this message
Old 10-07-2014, 07:46 PM   #6 (permalink)
Sammy123 is on a distinguished road
Default 12 volt power source for the Weber 32 36
Bazuki,
Did you have to ground out the wire coming from the yellow plug? Or did you just run a single wire from the yellow plug to the choke connection on the carb?
Sammy123 is offline   Reply With Quote Quick reply to this message
Old 10-07-2014, 07:50 PM   #7 (permalink)
Default Weber 32 36 install on Suzuki Samurai
Bazuki,
Did you have to ground out the wire running from the yellow plug to the electric choke? Or did you just run a single wire from the yellow plug to the electric choke?
Old 10-31-2017, 03:50 PM   #8 (permalink)
Texas_Republic is on a distinguished road
The link above didnt appear to do anything except take me to some parts website. I am also having trouble with a weber carb that was installed prior to me buying the zuk. There is a vacuum leak somewhere near the adapter plate.
Texas_Republic is offline   Reply With Quote Quick reply to this message
Old 10-31-2017, 04:39 PM   #9 (permalink)
Darrell.'s Avatar
Welcome to the forum. I've just uploaded the manual for the weber, don't know if it will help but always handy to have.
weber_manual
2005 Grand Vitara MT 1600se.
