Weber Carb - Suzuki Forums: Suzuki Forum Site
Old 01-05-2011, 12:15 AM   #1 (permalink)
jtrain1203 is on a distinguished road
Default Weber Carb
Hey guys i have some questions about the water choke on my weber. it dosent seem to be working kinda hard to start unless it is warm runs great once it gets warm though also i want to make sure that i have all the vaccume lines in use or capped off any info or pics would be great cant seem to find anything out as far as install on the weber. Thanks for the help
jtrain1203 is offline   Reply With Quote Quick reply to this message
Old 01-05-2011, 01:08 PM   #2 (permalink)
KJ2837 is on a distinguished road
Mine does the same thing. I have to hold the gas for a few when its cold outside till it warms up a bit then when I take off its ok.I dont have any pics but all of the vacum lines are easy to see.Just follow the lines you had on before you installed the weber and the ones not used plug them.The only problem Im still having with mine is the throttle sticks sometimes?Havent been able to figure that one out yet?I replaced my throttle cable and oiled it but it still sticks??
KJ2837 is offline   Reply With Quote Quick reply to this message
Old 01-10-2011, 05:57 PM   #3 (permalink)
Azelgin's Avatar
Is it just not returning to low idle? Mine had the throttle shaft sticking a little and wouldn't always let the throttle arm return back to bottom against the set screw. I worked over the shaft by tapping it back and forth, like the installation instructions suggested, but, it really didn't solve the problem. It seems like the lock tab washer they send wouldn't let me set the lever at the right tension, so, I got rid of it and used another nut to lock the existing nut it came with instead. Works great now.
Old 01-10-2011, 08:23 PM   #4 (permalink)
Thanks,Ill have to try that! Its really being a pain! I have tried everything I could think of and nothing has helped....
Old 01-10-2011, 08:36 PM   #5 (permalink)
Azelgin's Avatar
I also stole an arm off the old Hitachi and rigged up another return spring, but, the spring broke and the Weber still returns to idle, so, I think the new double nut lock is what really did the trick.
Old 01-11-2011, 03:08 PM   #6 (permalink)
well,i tried what you said so on the way home from we'll see how it does??
Old 01-11-2011, 08:27 PM   #7 (permalink)
Azelgin,so far so good.It did good on the way home,hope it stays that way..lol Thanks for the info!
Old 01-13-2011, 09:54 AM   #8 (permalink)
FXITDUDE is on a distinguished road
Garage
Default looking for info.
I am looking for info on the Weber carb is it rejetable or does it have adjustmen on mains? I know where the low speed is i found it but it is running really rich. Help if you can.
FXITDUDE is offline   Reply With Quote Quick reply to this message
Old 01-13-2011, 10:03 AM   #9 (permalink)
Yes, you can rejet it to your altitude.
Here are some basics:
Suzuki – How To Adjust A Weber Carburator | iZook - Suzuki 4x4 Tech Information, Accessories, Travel & Adventure
The Weber is a great carb if you get the tuning down right.
Bill
in old El Paso...
Old 01-13-2011, 10:22 AM   #10 (permalink)
Garage
Thanks Bill these forums are great you can get some good info here.
