Brake light staying on? - Suzuki Forums: Suzuki Forum Site
Old 12-16-2010, 11:11 AM   #1 (permalink)
KJ2837 is on a distinguished road
Default Brake light staying on?
Has anyone had your brake light on your zuk come on and stay on?It seems to be working properly (stopping & handbrake)??Any ideas??
KJ2837 is offline   Reply With Quote Quick reply to this message
Old 12-16-2010, 11:19 AM   #2 (permalink)
theres an electric switch that's triggered by the brake pedal. If the wires going to it are shorted or if the switch is bad, it can cause the brake lights to stay on. Check that switch to make sure it's operating correctly. If you unplug the switch and your lights go out you know the switch is faulty.
Old 12-16-2010, 11:22 AM   #3 (permalink)
Thanks baratacus,Ill check that today...
Old 12-16-2010, 12:40 PM   #4 (permalink)
zooki4x4's Avatar
If you're talking about the light in the dash it most likely is the hand brake switch gone bad or out of adjustment.
Old 12-16-2010, 12:51 PM   #5 (permalink)
Or low brake fluid.
Old 12-16-2010, 01:05 PM   #6 (permalink)
I shall check all of that,thanks guys!!
Old 12-16-2010, 08:51 PM   #7 (permalink)
citizendan is on a distinguished road
Garage
Smile checking brakes
Sense you're checking all of that you'll need to see if I've won the lotto there! Seriously, I have the dash light on also and sure enough the fluid level is down to the minimum line. However, that doesn't mean that I will top it off directly. Instead, I'll be checking the linings/pads. If you've changed linings before then you already know of the mess caused by topping the fluid. The question is how low is everything?
citizendan is offline   Reply With Quote Quick reply to this message
Old 12-16-2010, 09:46 PM   #8 (permalink)
oh! I thought He meant his tail light brake lights. Yeah the break light on the dash is usually low fluid in the brake reservoir.
Old 12-16-2010, 11:01 PM   #9 (permalink)
Unless you have had a sudden loss of brake fluid, you usually get an early warning every time you make a left hand turn as the brake light will flash as the brake fluid sloshes to the right side of the reservoir.
The e-brake switch wire runs underneath the driver seat and you should be able to first check that switch by unplugging the connector under the seat. If the light goes out, then it is either the switch or somewhere in the wire going to the connector.
Old 12-17-2010, 08:16 AM   #10 (permalink)
My fluid looked ok but i will look a bit closer...Yea,its my dash light.
