Rain leaks under dash - Suzuki Forums: Suzuki Forum Site
Old 12-15-2010, 02:45 PM   #1 (permalink)
VaderSS's Avatar
Garage
Default Rain leaks under dash
The rainy season has started in Northen California and during our last road-trip in the Samurai, our feet were dripped on from under the dash. When I would make a turn, the water would pour.
The top is a new Bestop and fits tightly.
I ran a piece of paper between the dash and bottom of the windshield seal while the leak was occuring, and it was dry.
I checked the cowl vent for proper drainage by pouring a glass of water in, and it instantly poured out of the drains under the hood, with no pooling in the tray under the vent.
The seal at the base of the windshield frame looks good at the edges, but I have no way of checking it once it disappears behind the dash. I guess I could run water from a hose against it to see if there are gaps. I can try that tonight.
Anyplace else I should be looking?
Wayne Bengston
Old 12-15-2010, 05:42 PM   #2 (permalink)
check the holes in the firewall. There are a few that cables and wires pass through that have rubber sealed grommets. I had a couple of them with old cracked grommets that would leak water under the dash when water hit them.
Old 12-15-2010, 11:42 PM   #3 (permalink)
VaderSS's Avatar
Garage
Thanks. I'll look at that tomorrow.
Wayne Bengston
Old 12-16-2010, 11:19 AM   #4 (permalink)
KJ2837 is on a distinguished road
do you have a radio ant on the cowl? That is if your leak is on the pass side?Mine was leaking something god awful and I traced it to the stero ant on the pass side of the cowl.A little clear sealant and all was good.Just an idea....
KJ2837 is offline   Reply With Quote Quick reply to this message
Old 12-16-2010, 11:55 AM   #5 (permalink)
VaderSS's Avatar
Garage
My antenna is on the windshield frame. Thanks for the tip though.
I'll look at the firewall after work today.
Wayne Bengston
Old 12-16-2010, 09:57 PM   #6 (permalink)
kos
kos's Avatar
Gallery: 3
kos is on a distinguished road
Hi VaderSS,
There's another thread with the same problem discussed. Could be of big help.
https://www.suzuki-forums.com/suzuki-...ping-foot.html
I still have the same problem after 5 years with my existing sammy. I have the air vents permanent shut off already...
Hope this helps!
kos is offline   Reply With Quote Quick reply to this message
Old 12-31-2010, 01:18 PM   #7 (permalink)
wachtelhund is on a distinguished road
I had the same problem on my Zuk. Fixed it by putting hose clamps on the connecting tubes to the two water drain hoses. Make sure the tubes and drain hoses are clean, then add hose clamps. The hoses connect horizintally. Sometimes while driving the slightest upward climb would cause the water to drain backwards from the drain tubes and leak at the connections. I've had no leaks since I added hose clamp on both drain tubes.
wachtelhund is offline   Reply With Quote Quick reply to this message
Old 12-31-2010, 08:55 PM   #8 (permalink)
VaderSS's Avatar
Garage
Thanks. I'll try that. The worst it has leaked was on a road trip in the mountains. Lots of uphill...
Wayne Bengston
Old 01-24-2011, 03:11 PM   #9 (permalink)
Chrisjb330 is on a distinguished road
Have a check of the bonnet hinges and around the rubber seal as the water could be running through there especially going uphill just an idea
Chrisjb330 is offline   Reply With Quote Quick reply to this message
Old 01-25-2011, 01:28 AM   #10 (permalink)
Garage
i had a loose windscreen washer nozel that let the water into the windscreen frame the frame has got a 12mm hole in it on both sides of 4x4 your antenna wire will go in one of them i also has a couple of cracks around the base of wiper pivot i just used white silicon as my 4x4 is white
