Engine Reassembly - Suzuki Forums: Suzuki Forum Site
Old 10-22-2010, 12:46 PM   #1 (permalink)
GIZMO is on a distinguished road
Default Engine Reassembly
My 1988 Sami has been in constant rebuild since the purchase. I removed the 1.3 and made alot of notes during disassemble. Now that I am putting it back together I have run into a problem that I saw before, but thought it was a simple fix when I put it back together. At first I thought it was the distributor cap turned 180*.....no prob i'll just turn it later. This was not the case. The wires have not been removed from the dist. The wires are all marked to which cylinder they were removed. The rotor was pointing to the #1 cylinder marked on rotor cap, with the marks aligned on the pulley's when I disassembled the motor. I have installed the timeing belt with the pulley marks aligned to the marks. I installed the distributor with the rotor pointing to the #1 cylinder. I said all that to say this.....the rotor cap will only fit on one way.
ROTOR CAP MARKED CYLINDER#1...........WIRE WENT TO CYCL# 2
#2................................CYCL# 4
#3................................CYCL# 1
#4................................CYCL# 3
If the rotor was turned 90* the wires would be correct.....can't do this.
The engine ran fine (except for the massive oil leak around the rear main) before it was taken apart.
As far as I can tell...when the marks on the pulleys are aligned properly Cyliners 1 and 4 are on compression strokes? Engine is not installed the vehicle yet....still on engine stand. Need some direction on what my choices are....hopefully it's just a wire sawp. I just wonder how it got this way in the first place.
GIZMO
GIZMO is offline   Reply With Quote Quick reply to this message
Old 10-22-2010, 03:41 PM   #2 (permalink)
if 1 and 4 are at the top of the "up" stroke with your pulley lined up with the marks and at TDC then your crank is in the correct position. Depending on which valve is open one is on the compression stroke the other on the exhaust stroke. If the cam is off then so will be your dizzy. If the marks are lined up on the cam gear then the cam shouldn't be off though.
Line your rotor up on the number 1 cylinder wire
Old 10-22-2010, 10:11 PM   #3 (permalink)
Mof
Mof's Avatar
Gallery: 14
Mof is on a distinguished road
Are you sure the dizzy isnt 180 deg out to the cam gear? the cap might be the right way round but the rotor is out 180 deg
The navigator made me do it!
http://www.lan-cor.com
Mof is offline   Reply With Quote Quick reply to this message
Old 10-23-2010, 02:22 PM   #4 (permalink)
zooki4x4's Avatar
On the 1.3 samurai engine when the timing marks are lined up on the engine. Both marks pointing up. You shound be pointing at the #4 cyl. on the distributor. The marks line up the cam for #4 not #1. So after install it would look to be 180 degrees off.
Old 10-24-2010, 02:27 AM   #5 (permalink)
the fact that he's only off by 1 cyl instead of 2 would indicate that it's more than just the dizzy being out 180 deg. set your cam markings and then put the plug wires on the dizzy with the assumption that the rotor is pointing at the number 4 and see how it goes.
Old 10-24-2010, 02:44 AM   #6 (permalink)
Mof
Mof's Avatar
Gallery: 14
Im supposing the camshaft hasnt turned 180 deg off
as the camshaft turns half speed of the crank
So the marks would still line up
Old 10-24-2010, 01:43 PM   #7 (permalink)
when the crank is at TDC, the pistons will be in the same position, no mater which revolution it is. whether or not its the exhaust stroke or the compression stroke is determined by the cam position. If the cam marks are set on the line then number 4 cylinder is going to be at the top of its compression stroke, (both exhaust and intake valves closed) while #1 cylinder is going to at the top of it's exhuast stroke (intake valve closed, exhaust valve open) Your dizzy can go in at 0 or 180, so if your dizzy is in bacwards then you can be off 180 but you can just rearange your wires so it's firing at the right position.
Old 11-04-2010, 06:30 PM   #8 (permalink)
Default Engine back in
After 4 months finally got engine together and installed today.
What I started with
[IMG][/IMG]
What I got now
[IMG][/IMG]
A few odds and ends to clean up tomorrow and will try and crank it up.
GIZMO
Old 11-05-2010, 08:47 AM   #9 (permalink)
yay! it looks so clean and pretty... go dirty it up!
