Ignition Feed Source - Suzuki Forums: Suzuki Forum Site
Old 10-07-2010, 03:22 PM   #1 (permalink)
Harpoon Hannah is on a distinguished road
Default Ignition Feed Source
I've come on here pretty frequently recently and have been able to find the answers and solutions I've needed so when I finally got stuck in my current rut I figured I'd post here.
I've done hours and hours of searching the web for the solution to my current situation. But to make a long story short I am now looking for an ignition power source to tap into for the relay for my new fuel pump. I've read that it is not wise to tap into the coil, and I've read of finding alternate ignition feeds, but I am slightly lost at this point. Obviously the requirement is that when I turn the car on, the fuel pump turns on and stays on until I turn the car off. I also am wondering how I tap into an ignition feed and wire it to the relay?
She's a 1987 Suzuki Samurai, and I am in the process of installing a 32/36 Weber carb with and echoke, a weber fuel pump, and a weber fuel pressure regulator.
Harpoon Hannah is offline   Reply With Quote Quick reply to this message
Old 10-07-2010, 09:21 PM   #2 (permalink)
well if you're taking off the stock carb, you can use one of the electrical connectors that is no longer in use. Some of them are hot with the ignition switch on. . I can't remember which of the connecters I tapped into, but one of those un-used carburetor connectors is hot with the ignition and I just used a spade crimp on the wire and slid it into the slot. Get a meter and start testing them with the ignition in the on position. Then turn the ignition off and see which ones still have +12v and which ones went out.
Old 10-08-2010, 03:44 AM   #3 (permalink)
Mof
Mof's Avatar
Gallery: 14
Mof is on a distinguished road
I have a 93 Samurai and I found a plug in the middle of the firewall that is on when the ign is on, its a round female bullet type plug above the coil on the firewall, I wired my seat heaters in this plug.
May be the same as your 87... maybe not
Mof is offline   Reply With Quote Quick reply to this message
