no turn signals front/rear & no wipers - Suzuki Forums: Suzuki Forum Site
Old 09-29-2010, 07:51 PM   #1 (permalink)
NigelAloha's Avatar
NigelAloha is on a distinguished road
Default no turn signals front/rear & no wipers
signals were working fine then nothing.
wipers went on for a second then died and got stuck halfway on the window.
any suggestions?
NigelAloha is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 04:02 AM   #2 (permalink)
NigelAloha's Avatar
signals will work sometimes...
wipers are dead...
Old 10-20-2010, 12:38 PM   #3 (permalink)
I would start by taking it apart, check all the pigtails for proper connection, check the ground make sure the screw didnt rattle out. See if its getting power to the swith.
Old 10-20-2010, 01:45 PM   #4 (permalink)
good chance that you have a loose or corroded connection in your steering column. Check the multi switches in the turn signal and the wiper controler, check the wire loom and connector for loose or shorted contacts.
Old 10-20-2010, 09:33 PM   #5 (permalink)
Default grounded right
Check all the grounds or the individual lights.
Check the plug in the steering column, under the bezel, near the dash.
Check the mounting of the wipers on the windshield.
Have you checked the fuses ?
IF it ever works it should work again.
If it stops and never starts again that is trouble. (read replace)
But sounds more like a ground (earth) issue.
You may be able to attach 12 volts to the wire to the wipers to bypass the switch...that will tell u if they will operate at all.
You can feed 12 volts to the individual lights to check them...if they light it is at or near the switch.
