Help!!!!!!!!!!!!!!!! - Suzuki Forums: Suzuki Forum Site
Old 09-29-2010, 03:21 AM   #1 (permalink)
monstazuk is on a distinguished road
Default Help!!!!!!!!!!!!!!!!
I have a leaf sprung zook with 5 inch snake racing lift, i want to put at least 33 inch tyres underneath the little girl!!! My issue is obviously tyre clearence and scrubbing. How can i come across this (apart from a little grinding).
your ideas will be greatly appreciated!!!!!!!!!!!!
Cheers...monstazuk..
monstazuk is offline   Reply With Quote Quick reply to this message
Old 09-29-2010, 07:38 AM   #2 (permalink)
Guest
You can move the front axle forward an inch or so by redrilling the perches.
Old 09-29-2010, 02:18 PM   #3 (permalink)
with a 5 inch lift you'll clear 33's without much work to the fenders. Your problem is going to be the front bumper. The bumper needs to come off and the tube behind it nees to be cut to clear the 33's. It's advisable to hammer down the flange inside the wheel well too. It's a 1/2 inch lip of sheet metal that will cut nicely into a tire if pushed hard enough.
Old 09-29-2010, 07:35 PM   #4 (permalink)
thanks for the info.... another question though, because the tyres are 12.5 inches wide i believe im going to run into trouble when i steer left or right and i'm not gonna have that same turning circle......
also how the hell do i get back to this thread without going through my email account? im having alot of trouble navigating this site????
Old 09-29-2010, 08:47 PM   #5 (permalink)
Bookmark this link
Old 09-30-2010, 05:57 PM   #6 (permalink)
SAMMYJAMMY is on a distinguished road
Petro Works Sells Tire Spacers To Stop The Rubbing
SAMMYJAMMY is offline   Reply With Quote Quick reply to this message
Old 09-30-2010, 09:35 PM   #7 (permalink)
dont you think wheel spacers will just make the problem worse? i thought of doing this i still will anyway so the car has a bit bigger stance and is a little more stable......
im thinking even with a 1.5 inch spacer its gonna make it worse
Old 09-30-2010, 10:01 PM   #8 (permalink)
kos
kos's Avatar
Gallery: 3
kos is on a distinguished road
Best solution in the long run would still be a fender trim. Trying to avoid the scrubbing by going higher and wider would just compromise your drivetrain or suspension not to mention your center of gravity. The fender trim will allow you to put in bigger tires and have a lower center of gravity.
One other alternative is to go for thinner tires with the wheel spacers.
Are you on a reversed shackle setup?
kos is offline   Reply With Quote Quick reply to this message
Old 09-30-2010, 10:27 PM   #9 (permalink)
he has leaf springs, not coils.
With leaf springs, you have the problem of the tires cutting into them if they are too large. If you bite into a leaf with the wheel cranked over while in 4wd, you can walk the wheel right up over it and snap the axel, birfield joints, and steering linkage. Its not pretty.
With 33,12.50's you will have light rubbing at full turn. with a spacer, or wheels with a smaller backspacing, you will eliminate that. You're only going to increase your turning radius by a few inches, more than worth the extra stability of a wider stance IMHO.
Old 10-01-2010, 04:30 AM   #10 (permalink)
kos
kos's Avatar
Gallery: 3
That's why I mentioned thinner tires and wheel spacers. A backspaced wheel would also help as you mentioned.
