87 Samurai Front Wheel knuckles - Suzuki Forums: Suzuki Forum Site
Old 09-19-2010, 04:35 PM   #1 (permalink)
garyvd is on a distinguished road
Default 87 Samurai Front Wheel knuckles
I recently bought an '87 Samurai hard top. It had quite a bit of front end noise in 4-w drive with the hubs engaged. I pulled the wheel assemblies and everything looked good and seemed smooth and quiet but the differential had quite a bit of end play and a little grinding when rotating by hand so I pulled it and got another clean, used one to replace it. Now I noticed that the front axles on both sides have maybe 1/8th to 3/16's inch of end play. Could that be where I was getting the rattle from and should I rebuild/replace the wheel knuckles too. The hubs seem good and they work smoothly.
Thanks a lot
garyvd
garyvd is offline   Reply With Quote Quick reply to this message
Old 09-20-2010, 12:03 AM   #2 (permalink)
did you get a complete axel? or just center section with the diff? Are you sure you got a front diff off of a 87?
Old 09-20-2010, 09:36 AM   #3 (permalink)
I got a front differential so far. I got it at Hawk's and they knew what I needed so I trust its the right one. It looks like new.
Old 09-20-2010, 09:52 AM   #4 (permalink)
so the new diff came with the side gears and you just slid the axle splines in?
Did Hawk tell you whether or not you would need to adjust them at all?
Old 09-20-2010, 11:28 AM   #5 (permalink)
Thanks for answering and yes thats the plan. Maybe I'm not being clear, I didn't remove the receiver/axle housing, just the differential and wheel/axle assemblies. I also got new steering knuckle and axle seals. So its ready to reassemble I just wanted to make sure I didn't need to do more to the steering knuckles since they seemed to have quite a bit of end play.
Old 11-02-2010, 09:58 PM   #6 (permalink)
lakeguy2005 is on a distinguished road
Try this for the front knuckle rebuild... I am doing the rear bearings and soon will be doing the front knuckle rebuild as well. Good luck.
lakeguy2005 is offline   Reply With Quote Quick reply to this message
