Truck just died - Suzuki Forums: Suzuki Forum Site
Old 09-12-2010, 10:47 PM   #1 (permalink)
gmwill29 is on a distinguished road
Default Truck just died
Stopped at a signal, truck sounded like it wound down and died. Getting spark at the plugs, cranks but does not run. Got gas, the fuel pump was replaced a little while back and can smell raw gas out the carb and the tail pipe. Don't think it's flooded because it's been sitting. Any ideas?
gmwill29 is offline   Reply With Quote Quick reply to this message
Old 09-13-2010, 11:14 AM   #2 (permalink)
happened to me about a month ago. It died while running. Starter cranked over, I could smell fuel, there was spark, but it would not fire up. I pulled the distributor cap and had fine metal powder/shavings in it. (i'd just replaced the cap and rotor a few months earlier) Put in a new cap and rotor and it fired right up and hasn't given me a problem since. Apparently the part was defective or I didn't get it seated well, and it had worn the contacts down unevenly. I was getting spark to half the cylinders and nothing to the other two.
Old 09-15-2010, 03:56 PM   #3 (permalink)
i replaced the cap and rotar and it works now!! thank you for the solution!
Old 09-20-2010, 07:54 AM   #4 (permalink)
jtilano828 is on a distinguished road
if it happen to your truck again after you tried those advises, try to let your all your fuel lines be flushed or blown using compressed air..there might be some scale deposits on your fuel lines especially the hoses(better if buy new hose)..these scale deposits when it reach your carb's float valve it will keep the valve open even when the carb is already flooded with gas and will let your engine stall even in the middle of a smooth run..
jtilano828 is offline   Reply With Quote Quick reply to this message
