samurai just died - Suzuki Forums: Suzuki Forum Site
Old 09-12-2010, 03:02 PM   #1 (permalink)
gmwill29 is on a distinguished road
Angry samurai just died
i was sitting at a light and the engine just completely died. i tried starting it and it just kept clicking and wanted to turn but it didnt. i replaced the coil but it still does the same thing. all the electronics work but i cant find anything on the web about how to fix it. whats happening?
gmwill29 is offline   Reply With Quote Quick reply to this message
Old 09-12-2010, 03:15 PM   #2 (permalink)
zooki4x4's Avatar
Sounds like you need the clickity starter fix. Lots of info on the board about how to do it. Not sure why it just died tho.
Old 09-12-2010, 03:28 PM   #3 (permalink)
i took out a spark plug to see if it was getting any spark but nothing was happening. it sounds like it wants to turn but it doesnt
Old 09-12-2010, 04:33 PM   #4 (permalink)
Daletec is on a distinguished road
Yep, no point in checking spark plugs until you get the engine turning over. Perform the Clickety Fix for your starter, it should start right up.
Daletec is offline   Reply With Quote Quick reply to this message
Old 09-12-2010, 04:49 PM   #5 (permalink)
zooki4x4's Avatar
You can use a jumper wire to test the starter. Just put everything in nutral and scotch the wheels park brake on. With the switch on take a 2' wire and touch the + pos terminal on the battery with one end and touch the other to the bottom wire on the starter. If it turns over or fires you need the clickity fix. Please be safe doing this.
Old 09-12-2010, 05:49 PM   #6 (permalink)
Here is what they are talking about...
Clicky Starter Fix
Bill
in old El Paso...
Old 09-12-2010, 06:16 PM   #7 (permalink)
GIZMO is on a distinguished road
I'm speaking from past experience.....it could be that the altenator has stopped charging an the battery ran the engine as long as it could and the engine died. The battery is dead and that is why it will not turn over (crank). You haven't said that you tried to jump-start said engine with another auto. If it does start and you disconnect the jumper cables....to see if the alt is charging and supplying the system with power for the coil...loosen and remove the positive cable on the battery. If the engine continues to run the alt is ok.
GIZMO
GIZMO is offline   Reply With Quote Quick reply to this message
Old 09-12-2010, 06:26 PM   #8 (permalink)
it is definately not a starter issue it wants to start with no problem but its not turning over. the battery is fine and the alternator is fine its just not wanting to turn. it died at a complete stop and wouldnt start up again.
Old 09-13-2010, 06:45 AM   #9 (permalink)
If it's not turning over, but you hear a clicking noise, then not enough power is getting to the starter to completely engage the gear or turn the motor. We're not saying the starter is bad, just not getting enough power.
Old 09-24-2010, 03:09 PM   #10 (permalink)
gmwill29........what ever became of this problem? I see that you want to replace the engine in a later thread. What did you find out?
GIZMO
