samurai engine swap not runing - Suzuki Forums: Suzuki Forum Site
Old 09-04-2010, 03:55 PM   #1 (permalink)
VIRGOPELO is on a distinguished road
Default samurai engine swap not runing
hi to all i an working on my engine swap i put a geo tracker 1.6l 16 valve i send hte wiring and de ecu to TRAIL T. and i have everinthig wel conected and i have sprak and the fuel injectors are working but the engine is not working at all any ideas
thanks
VIRGOPELO is offline   Reply With Quote Quick reply to this message
Old 09-04-2010, 04:01 PM   #2 (permalink)
Have you called Brent at Trail Tough yet?
His customer service is among the best!
Bill
in old El Paso...
Old 09-04-2010, 06:32 PM   #3 (permalink)
hi no i will on Tuesday and i know that they are very profesionals but i want to know if any of you guys had the same problem before because i an running with out ideas
thanks
Old 09-06-2010, 12:48 PM   #4 (permalink)
Banned
thanks
was eng. running before and using same ECU.
what year motor and ECU.
did you check.:
compression (id have done that on the floor on the pellet with bell on.
strobe the spark timing for spec initial spark?
if spark is way off then maybe belt has slipped. or the dang , crank cog key stripping deal. SEE TSB no new torque spec. 94 ft/lbs
did you have distributor removed.
i guess you have fuel wet spark plugs cuz say its injection.
is it flooding.
try secret unflood mode, WOT cuts all injections. all kicks.
we can start it, for sure.
just answer the questions.
have full tool set, compression gage, fuel pressure gage , timing light? volt meter.
or zero.
Old 09-06-2010, 08:54 PM   #5 (permalink)
Hi to all i already have the engine runing it was the valve timing problem but to make it work markers on the cam shaft pulley are not related it will be only my engine or it will be still out of timing
Old 09-07-2010, 05:49 AM   #6 (permalink)
Banned
Hi to all i already have the engine runing it was the valve timing problem'''
this is not hard, but there can be problems if you dont inspect the parts real careful.
but to make it work,
can see you didnt look at my Tbelt age, sure they are all related.
it will be only my engine> or it will be still out of timing?
did you see my post and my links.
see the 1.6L 16v Tbelt page.
here, the direct path,
my signature has the main page for the kickfix site.
here is TBelt main.
timing belt swap
here is 16v belt specific:
16v fast tbelt swap
if you read this careful you will discover your answer
the 16v CAM COG FITS 2 different motors, that is right.
a DOHC Swift ! too
http://kick-fix.com/t-belt/swift-SF413/DOHC.jpg
Old 09-07-2010, 08:35 AM   #7 (permalink)
Banned
come back, see post. i answered here and on kick side.
Old 09-07-2010, 10:02 PM   #8 (permalink)
Waooooooo exelent link ,thanks for the information
Old 09-08-2010, 08:17 AM   #9 (permalink)
Banned
see the revised parts finder.
how-to-find-EFI-parts
with new photo of the impossible rounting below manifold. intake small water tubes.
Old 09-08-2010, 08:19 AM   #10 (permalink)
Banned
and the full manual
here (not mine like above, the below is ACKs)
Ack's FAQ 1996 Geo Tracker Factory Service Manual
