1988 suzuki samurai high idle - Suzuki Forums: Suzuki Forum Site
Old 09-04-2010, 01:03 PM   #1 (permalink)
Richie is on a distinguished road
Default 1988 suzuki samurai high idle
hi guys i recently bought a 1988 samurai it has ran great since i bought it but as i was driving it today out of nowhere the rpm jumped to 3000 and will not come down i have backed off the throtle cable and idle adjustment completley and no results i think there is something going on with the vacume and lines any ideas
Richie is offline   Reply With Quote Quick reply to this message
Old 09-04-2010, 04:12 PM   #2 (permalink)
Print out and follow this article at Ack's Faq. Make sure your hoses are run correctly and are not cracked or leaking:
Ack's FAQ Samurai SJ-413 Carburetor Vacuum Line Maintenance
Bill
in old El Paso...
Old 09-05-2010, 09:52 PM   #3 (permalink)
littlered's Avatar
littlered is on a distinguished road
Default Idle Jet
I had that problem, it was with my carby, my idle jet had cracked and was somehow putting more fuel in at idle.
Its probably not this but just a thought.
Students can still afford fun, 89 SJ50 Tonka Truck
Usually on two wheels
littlered is offline   Reply With Quote Quick reply to this message
Old 09-07-2010, 08:42 AM   #4 (permalink)
Banned
3000 rpm
with full power?
that can only happen if:
too much air
and too much fuel to match air ( carbs job is to match air with good fuel mix , that is it. think of it as EFI in a brick.LOL)
so close the butterfly plate more and make sure throttle cable is not sticking.
if you close the butterfly plate (AKA throttle stop screw)
and the RPM dont drop then you have an air leak. ( causes lean condtion )
but if you punched out the jets.
and are already rich.
then air leaks cause high RPM immediatly.
with full power, due to rich + extra air = perfect high rpm running. see? sorry algebra leak.
If already too rich, then any added air causes high RPM with FULL power.
and for sure the carb has lots of parts, that can go bad. (ive boiled out hundreds)
to me its a black box.
so....
1: is the throttle jamming outside carb(box) Y/N
2: is the throttle plates jamming in carb , Y/N
3: are there air leaks below carb Y/N
if after doing above checks. no hits.?
then its carb rebuild time.
Google finding
engine induction air leaks
, bingo
