testing 4wd on tarmac- damage? - Suzuki Forums: Suzuki Forum Site
Old 09-01-2010, 07:13 AM   #1 (permalink)
jez
jez is on a distinguished road
Default testing 4wd on tarmac- damage?
Hi,
I'm selling my Samurai (i'm relocating abroad). Should I let potential buyers test the 4wd on normal roads? If so, for how long, and how much damage could this cause to the 4wd system?
I'm concerned because somebody tested it on a normal road, for approx 5 minutes, and reported that it was making clanging noices, and was faulty...
jez is offline   Reply With Quote Quick reply to this message
Old 09-01-2010, 09:09 AM   #2 (permalink)
This is an older vehicle. Unless the parts have been replaced or serviced regularly, I would not recommend it. I would also never let someone (even on a test drive) take the vehicle out without being in the vehicle myself. Unfortunately, most folks don't know how to use 4wd correctly and can cause damage. That being said...
With stock (open) differentials, you can run down the road in 4wd and not kill anything. It will put more of a strain on the front bits, but if everything is in good order it will hold up well.
If you have bad u-joints up front or a bad output shaft at the t-case, you will hear them (clanging/banging) when running in 4wd. The noises will also happen if you have any lift and you haven't done anything to correct the driveshaft/pinion angles.
Take a look at your components and see what actually broke.
Bill
in old El Paso...
Old 09-01-2010, 09:39 AM   #3 (permalink)
the person testing it may have broken it from complete inexperience. He may have been trying to shift on the fly or may not have even turned the manual hub locks. Like Bill said, "never let someone take a solo drive in your vehicle" If they break something on it they have no recourse and can just walk away, where you are stuck with a broken vehicle that is no longer in sellable condition. People are a lot less likely to drive it abusively if you are in the passenger seat.
Old 09-01-2010, 10:32 AM   #4 (permalink)
my996duc1's Avatar
my996duc1 is on a distinguished road
+1 for NO solo test drives.
I will even drive it first with them ridding to show them how it runs and operates. Then swap seats and let them drive.
I have run mine on the road in 4x4 to try things out but I don't lock the front hubs.
Maybe they didn't break it..... If they ran it at speed on the road and you usually only drive it off-road at slower speeds in 4x4 it may have had the problem all along but just not noticable off-road.
My front driveshaft would bang and clang at speed but not when driving slower. The driveshaft spun fine on the lift and looked fine but when operated down the road with a little speed (25-30mph) it would start making all kinds of noise.
Not broken but still needed to be corrected because of my lift.
1987 Tintop
my996duc1 is offline   Reply With Quote Quick reply to this message
Old 09-01-2010, 12:22 PM   #5 (permalink)
jez
Thanks everyone for your replies.
It was very stupid and naiev of me to let this person test drive it on his own. He didnt even ask if he could test drive in 4wd. He drove off in 2, but by the time he came speeding round the corner back to where I was waiting it was in 4wd- And he was going at some speed.
It was making a clanging noise, which seemed to be coming from the ront of the rear side.
I'm guessing there is nothing I can do about this person, other than learn from it?!
Old 09-01-2010, 03:07 PM   #6 (permalink)
jez
The person didnt do anything to the hub locks. I have only driven in 2wd to work and around town. To what extent would this have damaged the 4wd?
Old 09-01-2010, 10:36 PM   #7 (permalink)
I can think of a whole list of possible breaks... done most of them myself. But it will be easier if you crawl underneath and check a few things first.
1. Anything leaking? Trans, Transfer case or Diffs - they all have parts that can go boom. A leak can reveal a crack, and a crack can allow innards to move more than they are designed to do.
2. Driveshaft U-joints. They are an easy break and sometimes the problem isn't really visable. You may have to shake them around and see what moves.
3. Component Mounts. Engine, trans and t-case can all make bad noises when they aren't held in place correctly.
That's a good start.
Oh, and Welcome!
Bill
in old El Paso...
Old 09-02-2010, 03:03 PM   #8 (permalink)
if he didn't lock the hubs then that eliminates a bunch of problems he could have caused to the birfs and front axle. X2 on checking out the front drive shaft for balance. Mine was out of phase and I didn't even know untill Bill John straightened me out. Worked fine at low speeds, but over 25 it would start thumping.
Old 09-07-2010, 09:12 AM   #9 (permalink)
Banned
PART TIME 4wd has NO CENTER DIFFERENTIAL.
if the hubs are not locked its not in 4wd, so the points are moot.
the issue is wind up, here is the factory TSB explaining HOW to get UN WOUND UP! (ah RTM?)
in 4wd you can do this ( bad) easy by testing and turning on hard asphat or concrete.
so put 2 right wheels in the ditch (sand,gravel,dirit,or sod ) and engage 4wd
and say see it works.) or go off road.
you will and can wind it up on the road. in true 4wd,
some go straight and avoid this, but , why do that?, why stress part time system like that.? risk?
weakens and stretches the CHAIN TOO.
WHEN, the front hubs are not locked the axles spin free and are safe as bird.
unlocked the axles are making hot grease, that is all.
need wiki animations, have em.
this TSB is for dweebs , who do that and cant figure how to get undone, sad.
Old 09-07-2010, 09:20 AM   #10 (permalink)
Not really...
Putting it in 4wd and leaving the hubs unlocked will still spin the front driveshaft. If there is any play in the ujoints or the angles are wrong due to an incomplete lift, then you will definately have some noise if you spin that driveshaft. It can also make a bad part worse if you beat on it this way. This will happen on or off road.
(personal experiance)
Bill
in old El Paso...
