Popping out of 4WD Low - Suzuki Forums: Suzuki Forum Site
Old 08-31-2010, 11:29 AM   #1 (permalink)
Beerman is on a distinguished road
Default Popping out of 4WD Low
Did some wheeling with the big boys at the lake, dry sandstone terrain, and my passanger had to hold the transfer shifter to keep in from popping out of 4WD Low, is this normal when climbing or do I have a problem, didn't happen on the beach...
Thanks!
Beerman is offline   Reply With Quote Quick reply to this message
Old 08-31-2010, 12:44 PM   #2 (permalink)
grats's Avatar
Gallery: 3
grats is on a distinguished road
Their is a plastic piece called a shifter sheet where the stick meets
the transfercase, you need to unbolt the boot, pull the stick and
replace shifter sheet.
82 SJ410
97 Sidekick
08 SX4
grats is offline   Reply With Quote Quick reply to this message
Old 08-31-2010, 09:52 PM   #3 (permalink)
Is the lock bolt still in the shift lever ?
If it breaks or falls out it will not stay in gear.
Could be the problem.
Usually when the shift sheet goes it gets stuck in neutral or between the lo/hi location.
Changing both sheet and bolt could cheap fix it.
arlo
Old 09-01-2010, 08:48 AM   #4 (permalink)
Shifter Sheet:
Installation:
Tcase Fix
Also check your rubber t-case mounts. If you tore 1 (or more) the case will move around and the shifter could hit the edge of the body opening and come out of gear.
Bill
in old El Paso...
Old 09-19-2010, 01:29 PM   #5 (permalink)
gewhite is on a distinguished road
I am having this problem too but with my investigating. I feel like the boot is interfering with the shift lever. I took it off to look at the bushing but found that it stays in 4 Low with the boot out of the way. I have not thought of or found a fix.
gewhite is offline   Reply With Quote Quick reply to this message
