engine missing - Suzuki Forums: Suzuki Forum Site
Old 07-20-2010, 05:44 PM   #1 (permalink)
suk87 is on a distinguished road
Default engine missing
hey guys i have a problem with my samurai...i start it up idles fine sounds fine...put it in first gear and it runs fine then shift to second and it loses all power bogges down shift to third it tries to take off then does the same as second did and fourth and fifth does the same...after i run it hard for about 2 miles or so it clears up...does anyone have any ideas??? i have changed the plugs,wires,distibuter cap,rotor button trying to clear it up but no luck yet!
also since i put the new cap and button on i hear a noise coming for the distubuter any ideas about it? thanks
suk87 is offline   Reply With Quote Quick reply to this message
Old 07-25-2010, 12:53 AM   #2 (permalink)
RMKYMY's Avatar
RMKYMY is on a distinguished road
i had the same kind of thing happen to me, is it only when the clutch pedal is fully released ?
RMKYMY is offline   Reply With Quote Quick reply to this message
Old 07-25-2010, 12:11 PM   #3 (permalink)
If it clears up after a few miles then its probably the fuel mixture. A cold engine needs a higher fuel content in the fuel air mixture than a warm engine. Check to make sure you don't have any vacuum leaks and if you have old or worn vacuum hoses, replace them. (vacuum line is cheap and easy to replace) might check or replace the fuel filter too if it hasn't been done in a while.
Old 07-25-2010, 05:29 PM   #4 (permalink)
i check all vac lines and replaced fuel filter again still had same prob...i was guided to check the carb and when i opened it one of the brass barrels on the float was broken i have order a plastic float to replace the old one could that have been my problem? and where can i get the seals for the brake master cylinder resevoir
