Engine stalls won't idle - Suzuki Forums: Suzuki Forum Site
Old 06-11-2010, 10:50 PM   #1 (permalink)
Šeathrow's Avatar
Šeathrow is on a distinguished road
Default Engine stalls won't idle
Hey all
I recently blew the water pump and gasket , so i replaced it . I tryed to start my car but it won't idle and just stalls , i can keep it running if i put my foot down but it sounds rough and i noticed my weber carb is spitting out fuel like crazy can any 1 tell me what the go is ?? is it too much fuel or something to do with float level, its brand new weber 32/36 cheers
85 SJ50 Ute
05 Jimny
96 SJ80
Šeathrow is offline   Reply With Quote Quick reply to this message
Old 06-12-2010, 04:49 AM   #2 (permalink)
is it the 1.3 with mechanical fuel pump? or did you change to an electric fuel pump?
Are your fuel return lines hooked up to the correct tube?
Did you change anything other than the gasket and water pump? did you have the timing belt off for any reason?
Old 06-12-2010, 09:02 PM   #3 (permalink)
Šeathrow's Avatar
its 1.3 mechanical fuel pump
don't have fuel return lines setup
and i had to remove timing belt to install gasket and water pump but i followed the service manual to reinstall everything
do u think its somthing to do with too much fuel goin into carby ?
85 SJ50 Ute
05 Jimny
96 SJ80
Old 06-13-2010, 12:48 PM   #4 (permalink)
squid is on a distinguished road
when you lost the water pump, did the engine over heat? I was thinking a blown head gasket or cracked head.
squid is offline   Reply With Quote Quick reply to this message
Old 06-13-2010, 12:50 PM   #5 (permalink)
or timing belt is off a couple of teeth.
squid
Old 06-13-2010, 02:00 PM   #6 (permalink)
You wouldn't be flooding unless the fuel was dumping down the throat of the carb. it sounds like the timing is off. The fuel spilling out the carb though is from your return line not being connected. Your Samurai can't burn all of the fuel that pump puts out. It needs the return line plumbed to send the excess fuel back to the tank.
Old 06-13-2010, 09:35 PM   #7 (permalink)
Šeathrow's Avatar
Head gasket seems to be fine , i think its skipped a tooth i will check that out.
would u be able to spend me a pic or diagram of how the return line wants to be plumbed up and do i need a regulator?
85 SJ50 Ute
05 Jimny
96 SJ80
Old 06-19-2010, 04:33 PM   #8 (permalink)
87samurai_dunn is on a distinguished road
yes, any time a weber is run it needs to be regulated to abouth 3 lbs of fuel pressure is what mine runs at, without the regulator it will run but not as smooth as its supposed to and will flood a lot easier
87samurai_dunn is offline   Reply With Quote Quick reply to this message
