Another newbie series of questions - Suzuki Forums: Suzuki Forum Site
Old 06-04-2010, 05:13 PM   #1 (permalink)
comanche79p is on a distinguished road
Default Another newbie series of questions
I have been reading as much as I can on here about the options available for Samurai's, and sometimes get a little confused. I am going next week to get my "new" '86 stock Sammy and want to do a few thing with it. I want to keep the ride and handling good on the hiway and do a lift enough to handle 30" tires. I bought this in place of a 4-wheeler and use it to putter around to and from my hunting spots which include quite a bit of sand in a river bottom and to and from work. I am not a hard core 4 wheeler, but would like to get around when I needed to.
I have been looking at the Rocky Road Wrangler under spring lift kit to start with. Here are my questions.
1. Is this a good conversion?
2. Exactly what springs are needed (year model? stock?)
3. I am not what you would call a mechanic, but do OK with a set of wrenches, so is this a fairly straight forward conversion?
4. Is this enough lift for 30" tires?
5. What will I give up in doing this conversion? I would expect to loose some fuel economy and power, but what else would I give up?
6. What else would be needed to complete this conversion? What about gearing? shocks?, drive shaft? steering?
This is my first post, so any direction would be appreciated.
comanche79p is offline   Reply With Quote Quick reply to this message
Old 06-04-2010, 06:18 PM   #2 (permalink)
I just recently became aware of Sky manufacturings YJ spring under lift and would recommend Sky over RRO any day of the week. For clearing 30's you don't need lift springs, you can just run stock YJ spings. For running on soft sand a wide tire is good. One of the few times a wide tire is advantageous. You will loose a little power and 5th gear will only be a downhill option on the freeways. You can get a lower gear transfer case or you can lower your differential gears. The T-case is recommended if you plan on dropping the low range way down but keep the high range at a mild reduction. If you don't need super low gears then it would be better to just reduce the diff gears. Reducing the differential takes a lot of the load off of your driveshaft, ujoints, T-case mounts and output shaft.
A header makes a big difference in power on the little 1.3 engine. You can get away with the stock carb if it's in good shape. If you live in an area that abides to the CARB standard for smog checking then you should keep the stock carb on it. With 30/10.5's you should be able to clear the springs, but I'd advise you to get some wheels with a short back-spacing. It ensures your wheels have all the clearance they need, and it widens the stance a little bit, giving you a little more stability. You shouldn't need any steering assist, but depending on how high you lift it you may need a high steer or a zbar. A drop pitman is only good for a couple inches of lift. You'll need longer shocks and extended brake lines too... don't know if they come with the kit.
Old 06-04-2010, 07:18 PM   #3 (permalink)
Thanks! This is the kind of info I am looking for.
It has a Weber carb on it.
I looked at the Sky website and didn't see the YJ conversion.
So, if I understand you, I could get front and rear stock YJ springs and the Sky YJ conversion (spring under), have enough room for 30" tires with a little back spacing on a set of new wheels. Check and see if the kit comes with longer brake lines and any steering modification.
Put it in, drive it a while to see if I want the change the gearing in the diff's or the transfer case, or both.
I also read good things about Trail Tough kits. Any comments on those?
I can't wait to get started-I think??
Old 06-05-2010, 09:08 AM   #4 (permalink)
this is just the baic suspension hardware:
Sky YJ Wrangler Leaf Spring Swap Kits - Suspension Kits - 86-95 Samurai - Suzuki
Trail tough also makes a great product and has awesome customer service
Trail Tough YJ Wrangler Leaf Spring Suspension Kits - Suspension Kits - 86-95 Samurai - Suzuki
Old 06-05-2010, 05:07 PM   #5 (permalink)
Baratacus,
Thanks for the replies. I think I will start with giving Trail Tough and Sky a call next week.
Thank you!
Old 06-06-2010, 10:25 AM   #6 (permalink)
Default Where do I start?
Here is my new ride.
Another newbie series of questions-sammyengine.jpg   Another newbie series of questions-sammyleftside.jpg
Old 06-06-2010, 12:47 PM   #7 (permalink)
mule's Avatar
looks like you got a good one, that engine bay is real clean. congrats, and keep us posted on what you end up doing
[COLOR="Red"][SIZE="5"]I [SIZE="6"][B][U]HATE[/U][/B][/SIZE] [I]Consumer Reports[/I] :mad:[/SIZE][/COLOR]
mule is offline   Reply With Quote Quick reply to this message
Old 06-06-2010, 01:32 PM   #8 (permalink)
wow that is a super clean rig! I wish I could find a convertible hardtop for a reasonable price, they're so expensive! A header will help that carburettor breath better, should make a big difference in power.
Old 06-06-2010, 01:47 PM   #9 (permalink)
Thanks, Mule.
There appears to not be an end to what you can do to one of these rigs. I don't want to half e$$ do any mods. I think I like the looks of the YJ bolt on conversion from Sky that was pointed out in an earlier post and was wanting to stay spring under until I decided something different. I am leaning toward a little body lift and the YJ spring under right now. I guess you could change from spring under to spring over later?? I plan to get on the phone tomorrow and ask a lot of questions from a couple of vendors. I want to get the foundation right to start with and go from there. It looks like after a certain amout of lift things might get a little complicated, and after a certain amount of tire size, it gets complicated and somewhat expensive. At least that is what I am reading into what is posted on some of the forums. So right now this is what I am thinking.
1. Sky YJ stock springs (under)
2. 1" body lift
3. wider offset wheels and 30" tires
4. fender flares
Later on
1. Header and 2" exhaust
2. lower geared differentials
Anyone have any comments?
Old 06-06-2010, 07:40 PM   #10 (permalink)
id go lower transfer gears instead of lower diff gears, especially if its going to be used offroad. for example, the 4.16 transfer ratio's have a 12% reduction in high range which would bring it back to stock gear ratios with larger tires which is good for fuel economy around town and on the highway, and it also reduces low range by 83%, which is great for offroad.
there are other ratio's that range all the way to 6.5, off memory is a 170% reduction of low range... please feel free to correct my figures anyone, i did all those numbers off memory...
