Jimny speedo problem - Suzuki Forums: Suzuki Forum Site
LinkBack Thread Tools
Old 06-04-2010, 02:55 PM
mikejonesjimny is on a distinguished road
Default Jimny speedo problem
most of the time my speedo reads zero
then suddenly it begins to work perfectly
then it stops working again, and so on
i've removed instrument housing, and waggled the 2 big connectors on the back of it, and i've removed the speed sensor, sprayed it with WD40, and put it back
but still the same
Any ideas ????
mikejonesjimny is offline   Quick reply to this message
Old 06-05-2010, 09:57 PM
ack
ack's Avatar
Default speedo problems...
The drive cable may be broken. Every once in a while, the broken ends may mesh together for a moment causing the speedo needle to jump...
You should be able to replace the drive cable by disconnecting it at the Transfer case, pulling it out of it's drive sleeve then installing a new drive cable. You might also disconnect the cable from the cluster so that, if the broken piece does not pull out, the new cable will push the broken piece out of the sleeve at the cluster end.
That's my theory...
...and I hope it helps!
- Ack
'14 Ford Transit Connect DD
ack is offline   Quick reply to this message
Old 06-06-2010, 12:10 AM
squid is on a distinguished road
Us American Samuria owners forget that the world has moved on. The jimny uses an electronic signal from speed sensor to operate the speedometer. there have been several older posts that sensor failing. that is where I would start.
Squid
88 samurai - daily driver
squid is offline   Quick reply to this message
Old 06-06-2010, 11:34 AM
Thanks for that info
Old 06-08-2010, 09:26 PM
87silver's Avatar
Gallery: 16
87silver is on a distinguished road
Not much that can go wrong with the cable. I've only seen one rupture at the case end from rocks; the set screw sheared off and it wasn't easy to remove.
[COLOR="Red"]______________[/COLOR]
[IMG]https://www.suzuki-forums.com/gallery/images/54160/small/1_samurai_nameplate_359x86.jpg[/IMG]
[I][COLOR="Red"][FONT="Comic Sans MS][U]"Where it all began"[/U][/FONT][/COLOR][/I]
87silver is offline   Quick reply to this message
Old 08-03-2010, 10:44 AM
Default What next
I've put in another speed sensor
But still the same
Is a second hand instrument cluster now the answer ?!
OR is wiring easy to check for breaks ?
