steering shaking - Suzuki Forums: Suzuki Forum Site
Old 05-08-2010, 01:52 PM   #1 (permalink)
bobby dazzler is on a distinguished road
Default steering shaking
hi all new to the site looks good hopefully might get some info of u all i have a suzuki jimny on a 03 plate estate the steering shakes badly in between 40 and 50 mph had tracking done and balancing and still doing it please help its in the garage at the moment but they cant find any thing
bobby dazzler is offline   Reply With Quote Quick reply to this message
Old 05-08-2010, 02:15 PM   #2 (permalink)
distantcamera is on a distinguished road
Hi,
Does it have the weird triangular alloy wheels? During my search for Jimny knowledge I saw it mentioned that those are nearly impossible to balance because they warp slightly and go out of balance when you tighten up the wheel nuts.
distantcamera is offline   Reply With Quote Quick reply to this message
Old 05-08-2010, 02:31 PM   #3 (permalink)
no there not the triangular wheels i was told it could be king pins but i am not sure could be a number of things its just breaking it down to the one thing
Old 05-10-2010, 03:43 PM   #4 (permalink)
squid is on a distinguished road
If you have triangle shape wheels, no wonder it is all bouncy. Here in the USA we only use round wheels, Much smoother!!
squid is offline   Reply With Quote Quick reply to this message
Old 05-11-2010, 07:42 AM   #5 (permalink)
ack
ack's Avatar
If the mechanics can't figure it out, you need to find another garage!
"Death Wobble" involves the following:
1 Worn steering linkage components (tie rod ends, etc.)
2 Worn Birfield joint seals.
3 Worn steering stablizer.
4 Bad alignment.
5 Incorrect installation of a suspension lift.
6 Worn wheel bearings.
7 Worn kingpin bearings.
8. Damaged or out-of-balance tires.
Of the above - 8, 1, 6, 7 and 5 (in that order) are the usual culprits.
Of special note is 5, above. If your truck has a susupension lift, it is possible that whomever did the lift did not position the front differential so that the face of the input flange is parallel to the face of the transfer case's output flange before welding on the spring perches. Not doing so causes a permanent change in the Caster angle which can cause a "wobble" effect similar to that of the banged-up front wheels of a grocery store shopping cart. It also causes accelerated wear on the front driveshaft u-joints...
I hope that this helps!
- Ack
'14 Ford Transit Connect DD
Old 05-11-2010, 10:57 AM   #6 (permalink)
03 is a coily so the spring perches aren't an issue, but the control arms are.
Also check your bushings on your suspension and check your shocks. If you damaged or wore out one of your shocks, the extra load would destroy the suspension bushings on that side. If not remedied a problem like that will eventually destroy the wheel bearing.
Old 05-11-2010, 06:37 PM   #7 (permalink)
ack
ack's Avatar
DARN the luck!
We don't have them here... GRRRR.....
Curse you, Consumers' Union!
- Ack
Old 05-12-2010, 04:01 PM   #8 (permalink)
robikun is on a distinguished road
Smile shaky stearing
hi guys,
i have s jimny 2003 model. between 60-70 kmh while breaking especially downhill the steering started to shake violently. eventually i was using a handbrake to avoid the shake.
this car have had 100k on the clock. i decided to change the front rotors and breakpads. this completely eliminated the shake. very happy.
a rotor costs about AUD120-150 a pop. garage has charged AUD300 for work incl rotors.
cheers
robi
robikun is offline   Reply With Quote Quick reply to this message
