Advancing timing - Suzuki Forums: Suzuki Forum Site
Old 04-27-2010, 08:16 AM   #1 (permalink)
Ğeathrow's Avatar
Ğeathrow is on a distinguished road
Default Advancing timing
hey
i was looking to advance my timing from 0 to 10 deg on my sj80 , could i plz get some info on wat i need to do and if its worth doin ?? cheers
85 SJ50 Ute
05 Jimny
96 SJ80
Ğeathrow is offline   Reply With Quote Quick reply to this message
Old 04-29-2010, 01:56 AM   #2 (permalink)
Ğeathrow's Avatar
and also where is the timing check window on 96 sj80 ?
85 SJ50 Ute
05 Jimny
96 SJ80
Old 04-29-2010, 11:53 AM   #3 (permalink)
What engine is in your SJ80? There were a couple different configurations used and I don't know which one you have.
Old 04-29-2010, 04:00 PM   #4 (permalink)
why would you do this?
are you talking ignition timing, cam timing, etc?
what are you trying to achieve?
Old 04-30-2010, 09:08 PM   #5 (permalink)
Ğeathrow's Avatar
engine is a G13BA and i;m trying to achieve correct iginition timing .
85 SJ50 Ute
05 Jimny
96 SJ80
Old 05-01-2010, 11:03 AM   #6 (permalink)
stock timing is 8 degrees plus or minus 1 degree. 10 degrees is around one degree advanced past stock and should be just fine. I run mine at 10 degrees.
Old 05-01-2010, 07:25 PM   #7 (permalink)
Ğeathrow's Avatar
rightio tys baratacus
85 SJ50 Ute
05 Jimny
96 SJ80
Old 05-01-2010, 07:28 PM   #8 (permalink)
Ğeathrow's Avatar
btw where is the timing check window i got a s413 manual shows it on tranny
85 SJ50 Ute
05 Jimny
96 SJ80
Old 05-02-2010, 02:48 AM   #9 (permalink)
there should be a timing mark on the crank pully on the front of the engine and a flange plate with the degree markings on it. It's shrouded by the fan cowling and and a bunch of belts and hoses. It's hard to get the light on it. There's also an access port on the bell housing with a rubber cap over it. That hole will allow you to see the rear flywheel which also has a timing mark for 10deg BTDC.
Old 05-02-2010, 08:04 PM   #10 (permalink)
Ğeathrow's Avatar
cheers mate
85 SJ50 Ute
05 Jimny
96 SJ80
