94 Samurai Code 31 - Suzuki Forums: Suzuki Forum Site
Old 04-22-2010, 09:50 AM   #1 (permalink)
gmos40@yahoo.com is on a distinguished road
Cool 94 Samurai Code 31
I have a 94 Samurai and the cell flashes 3 then 1. Does anyone know what this code means.
gmos40@yahoo.com is offline   Reply With Quote Quick reply to this message
Old 04-22-2010, 09:52 AM   #2 (permalink)
8995 SIDEKICK & SAMURAI w/TBI FUEL INJECTION
12 All Clear (No Fault Detected)
13 O2 Sensor circuit
14 Coolant Temperature Sensor Circuit
15 Coolant Temperature Sensor Circuit
21 Throttle Position Sensor Circuit
22 Throttle Position Sensor Circuit
23 Intake Air Temperature Sensor Circuit
24 Vehicle Speed Sensor Circuit
25 Intake Air Temperature Sensor Circuit
31 Atmospheric Pressure Sensor Circuit
32 Atmospheric Pressure Sensor Circuit
41 Ignition Signal Circuit
42 Crank Angle Sensor Circuit
44 Idle Switch Sensor Circuit
45 Idle Switch Sensor Circuit
51 EGR System & Recirculated Exhaust Gas Temperature Sensor
53 Ground Circuit
54 Fifth Gear Switch Circuit
71 Test Switch Circuit
ON ECM failure
Bill
in old El Paso...
Old 04-22-2010, 10:13 AM   #3 (permalink)
Default thanks
Thanks Bill, I appreciate it. I'll do a search on Atmospheric Pressure Sensor Circuit now.
Old 04-22-2010, 01:30 PM   #4 (permalink)
wrenchwoman's Avatar
I did a little searching and from what I read it may be indicative of a problem with your MAP sensor. Someone here will tell you a better and more definitive answer.
Old 04-22-2010, 03:44 PM   #5 (permalink)
Guest
Code 31 is Manifold Absolute Pressure Sensor (MAP sensor). The MAP sensor is usually mounted on the bulkhead and has a pipe going to the inlet manifold. Check that the pipe is in good condition and that the inline filter is clean, then check that you have 5V and ground on two of the terminals, the voltage on the other terminal should vary with load.
Old 04-22-2010, 06:11 PM   #6 (permalink)
Like Rhinoman posted, check all the hoses and connectors going to the MAP sensor. The sensor itself rarely goes out. When they do they are one of the more expensive pieces of plastic under the hood. Costs almost as much for a rebuilt throttle body.
