87 Samurai 4x4 Stuck, can't shift - Suzuki Forums: Suzuki Forum Site
Old 04-21-2010, 07:41 PM   #1 (permalink)
KC9
KC9 is on a distinguished road
Default 87 Samurai 4x4 Stuck, can't shift
Hi,
I am new to the Samurai world, just bought an 87. It runs great, started messin with the 4WD and it froze in place, now when I put the truck in 1st it won't go, it is like it is stuck in Nuetral. I can't get the 4WD to go into 2H or 4H or N...nothing. Any ideas?
Thanks!
KC9 is offline   Reply With Quote Quick reply to this message
Old 04-21-2010, 11:21 PM   #2 (permalink)
easy fix, take out the transfer case shifter, and replace the bushing on the end of the shifter, yours is worn out thats why its getting stuck in N, this is a common fix for samurai's.
Old 04-22-2010, 11:43 AM   #3 (permalink)
my996duc1's Avatar
my996duc1 is on a distinguished road
exactly what he said... easy fix.
Might be a good time to change both trans and t-case bushings.
Here is a vendor that sells both of the different types made (poly or brass) :
Sloppy Shifter Fix Bushings and Bolts - Transfer Case - Samurai - Suzuki
1987 Tintop
my996duc1 is offline   Reply With Quote Quick reply to this message
Old 04-24-2010, 03:55 AM   #4 (permalink)
piece of cake. took me 15 minutes from removing the first bolt to replacing the last one, including cleaning out the old bushing which was in dozens of tiny tiny pieces. i used this article. read it just once and was able to do it all myself. hope this helps:...
Suzuki Samurai Transfer Case Shifter Bushing Repair
Old 04-24-2010, 03:56 PM   #5 (permalink)
alternator's Avatar
Gallery: 4
When that happened to me, I was heart broken, thought something had gone wrong with my T/C. I took it to a mechanic and wasted a lot of money, and then it turned out tobe just the bushing
Happened again later, but I had learnt a lesson this time and replaced the bushing myself. But I had to fix the position of the shifter using a large flat screw driver.
Old 09-08-2013, 07:56 AM   #6 (permalink)
smbearkat90 is on a distinguished road
Default Also can't shift
This is a good forum for me. Yesterday I traded my kawaski mule for Samauri....best decision I made. My son and I drove off and on and decided to check out the 4WD. Drove on lake dam 4 times then I could not get into any 4WD gear. Stuck in netural. Afer reading this forum...I went out and took the stick out and sure enough the bushing is gone!!! Those dang plastic are worthless. I am going to get a brass ones. Yes I agreed with all user above...it is easy. I hope a auto part store carry these.
smbearkat90 is offline   Reply With Quote Quick reply to this message
Old 09-13-2013, 09:47 AM   #7 (permalink)
Beerman is on a distinguished road
Get the set of Poly from petroworks. On the tranny you have to deform the bushing to get by a pair of pins. They will outlast the OEM's
Prost!
87 Sammy, Stock 1300, Stock Carb with Vent Tube,Pacesetter Headers, 2" exhaust, no-cat, 33s on Shackle Lift. EZ-Lockers up front.
Beerman is offline   Reply With Quote Quick reply to this message
