weber whine - Suzuki Forums: Suzuki Forum Site
Old 03-22-2010, 09:27 PM   #1 (permalink)
bcarter5's Avatar
bcarter5 is on a distinguished road
Default weber whine
engine was running a little rough. noticed carb was loose tightened the two loose nuts now it whines loud and will not idle.i am cant figure it out.if i loosen the nuts it stops.but they need to be tight.whwt should i do?
bcarter5 is offline   Reply With Quote Quick reply to this message
Old 03-23-2010, 01:41 PM   #2 (permalink)
zooki4x4's Avatar
It sounds like a vaccume leak. Get a new gasket and remount. You might be able to put a little RTV on the old gasket and try.
Old 03-23-2010, 02:08 PM   #3 (permalink)
Daletec is on a distinguished road
Also check the idle mixture screw at the base of the carb, if it's open too far, it can whine at you and show the same symptoms as a vacuum leak.
Daletec is offline   Reply With Quote Quick reply to this message
