87 sami transfer case grind - Suzuki Forums: Suzuki Forum Site
Old 03-21-2010, 10:38 PM   #1 (permalink)
87studzuki is on a distinguished road
Default 87 sami transfer case grind
so a week ago i had to replace the detieriorated t-case bushin cause my rig got stuck in nuetral well a few days later my transfer case started to progressively get louder and louder noise in it but the thing is i have it up on the lift and run threw my gears and as long as im not givin it gas it doesnt make a sound as the front pinion when in an unstressed position every thing is quiet but when i give it gas and the pinion slides into the transfer case maybe a 16th of an inch the noise persists what is this and is it cheapply fixable also is a geo transfer case easily swapped into use with my sami driveline Thankyou
87studzuki is offline   Reply With Quote Quick reply to this message
Old 03-22-2010, 06:38 PM   #2 (permalink)
Last part first...
The Sammy has a 'divorced' transfer case meaning it is a seperate component. The Geo Tracker uses a transfer case that is attached to the transmission. So no, it won't swap out.
Two things may be happening in your t-case. The first may be a worn counter shaft that is causing your gears to chatter.
The other possibility could be the front output gear or bearing. It's a 20 year old t-case... treat it to a rebuild and it can fix most of the possible problems. Wait too long and you could end up like this... BTDT.
Caused by worn counter shaft
Bill
in old El Paso...
Old 03-23-2010, 06:50 PM   #3 (permalink)
thanks i was just tryin to figure out the whole deal and im not real familiar with the geos but im in the process of either findin a stock case or orderin a grs II from petro works thanks for the info
Old 03-23-2010, 10:08 PM   #4 (permalink)
Even a stock rebuilt t-case will cost some bucks, so if you are looking to replace yours anyway, go with a rebuilt with gears to offset any larger tires you may be planning to use. A GRSII will take good care of you up to a 31" tire. If you buy it complete (ready to bolt in), then you can trust the work that Gary and his staff put into it.
Bill
in old El Paso...
