playing before gear change - Suzuki Forums: Suzuki Forum Site
Old 03-17-2010, 11:17 PM   #1 (permalink)
87samurai_dunn is on a distinguished road
Default playing before gear change
i rescently decided i need lower gears for the offroad, im running 31s with stock gears in the transfer case and axels, im tearing out the thirds to do a spool in the back and lockright in the front so i was wondering if it would just be easier to do 5.38 ring and pinions in the axels opposed to dumping the money into the transfer case, this is a sort of daily driver and highway right now is 4rth gear to keep 65, with the 5.38s could i still drive highway? and is there a problem with gear thiness on these gears?, well heres some pics of me playin today anyways just cuz i know i like seeing other peoples rigs
playing before gear change-gwar.jpg   playing before gear change-gwar-2.jpg   playing before gear change-gwar-3.jpg
87samurai_dunn is offline   Reply With Quote Quick reply to this message
Old 03-18-2010, 08:42 AM   #2 (permalink)
Gallery: 8
The 5.38 R&P is 44% underdrive. The 31" tires are 13% overdrive. If you want to return your 5th gearing to near stock, it's not a good match. If you can find a set of 4.30 gears (rare) you'd be very close, within 2%. BUT, ....
Early Samurai 5th overdrive gears were 0.795:1. The later 88.5+ 5th ratio was changed to 0.865:1, about 8-9% lower, which makes it a easier to pull 5th on the highway (at slightly higher rpm). If you factor in your early 5th and larger tires, an R&P of around 4.57 - 4.62 would be perfect to get your 5th back for the highway. True, 1st-4th gears would be a bit (8%) lower, but you'll never really notice. [My overall gearing is about 12% lower than stock and other than being a bit buzzy, it's all good.]
Old 03-18-2010, 11:41 AM   #3 (permalink)
my996duc1's Avatar
my996duc1 is on a distinguished road
I have stock t-case and 5.12 r&p (hybrid rear) on 31" tires = 4200rpm at 65mph. Mine was setup this way when I bought it but I would have done it differently with less r&p gearing and also do the t-case.
I want a lower crawl BUT now if I do the t-case with the GRS II to get a better low gear crawl I am going to be running 700rpm-ish higher I could go to a 33" tire and drop 300rpm-ish but that still has me running 4600 rpm at 65mph.
Not sure what rpm is too high to run sustained on a daily driver but it feels already kinda high at 4200rpm. I guess that would be a good question for a new topic.....
Here are some good tables to figure gearing and speed info :
Gearing Tables
Gear Calculator
Here is some reading on gearing by Trail Tough :
Question - Transfer case gears or axle gears?
1987 Tintop
my996duc1 is offline   Reply With Quote Quick reply to this message
Old 03-18-2010, 01:24 PM   #4 (permalink)
4.62's would be easier to find out of a pair of track/kick front third members, but a GRS II is a better compromise for both on road and off road.
Bill
in old El Paso...
Old 03-19-2010, 10:07 PM   #5 (permalink)
Gallery: 8
Good observation (wish I'd though of it).
The GRS II has an 18% high-range reduction, which puts 31's about 4% lower than stock -- a good choice. And the 4.89:1 low-range will work well with 31's for most off-roading.
Old 03-20-2010, 01:22 AM   #6 (permalink)
will the track/kick 3rds bolt right up or would i have to swap gears?
Old 03-20-2010, 09:05 AM   #7 (permalink)
The front will (22 spline shafts) but the rear won't (26 spline shafts).
But I would suggest swapping the gears using a kit for both. The track/kick housings are aluminum and will crack like an egg if you whack it on something on the trail. The Samurai housings are steel and can take a beating.
Bill
in old El Paso...
Old 03-20-2010, 04:09 PM   #8 (permalink)
where could i get the kits?
Old 03-20-2010, 05:35 PM   #9 (permalink)
Petroworks - Ring & Pinion Modification Kit
Drive Train - PetroWorks
Low Range Off Road - Carrier Pin Retaining Cans
Carrier Pin Retaining Cans (Sidekick Gear Swaps & 5.38 gears) - Axles - Samurai - Suzuki
Trail Tough - Carrier Pin Retaining Cans
Bill
in old El Paso...
Old 10-24-2013, 11:20 AM   #10 (permalink)
suzukiman420 is on a distinguished road
Garage
I have a 87 samurai and have 6.5.1 transfer case and I'm running 33 inch super swampers and now and looking to do an R & P swap I was thinking to go with the 5.38 but is that to much for 33" I do drive this rig every day and if I no I will not b goin off rd or if I ko I am goin on hiway I do have 31 that I put on. any help would be much appreciated I have to redo my back 3erd member anywaysso figured it was a good time to put new gears In.
suzukiman420 is offline   Reply With Quote Quick reply to this message
