New here, 1988 Samurai project - Suzuki Forums: Suzuki Forum Site
Old 03-17-2010, 06:55 AM   #1 (permalink)
Daletec is on a distinguished road
Default New here, 1988 Samurai project
Folks, I have been reading here for over a week, now. I got to page 45 in this forum. I am new to Suzuki Samurais, I was a VW Type I enthusiast for several years, then got out of the car hobby, family, job, etc. This past Friday I paid $1800 for a stock 1988 SJ413. My new top should be here this Friday. Weber 34/34 should be here, today, Shift sheet and bolt kit from Petroworks should be here Friday, also. I will order the Thorley exhaust next week. Also going to purchase a used 1.3 or 1.6 for a rebuild, might also get a tranny and transfer case. I have been reading and searching on lift kits. My intended use is daily-driver with some logging road, light trail riding with my 9 year old this spring/summer. I am also looking at the various fiberglass hard tops. I will be posting and participating as this project takes shape, lots of knowledgeable folks on here. I may need the most assistance with body/metal work. The rockers are trashed(rust) and the rear quarters are eaten up. I would like to take it down the metal, weld it up, sand, prime and paint. I don't need the tallest lift, maybe 2" and I'd like to get the best ride I can. I think if I can get 80 to 90 BHP, I should be able to drive the highways without much trouble. I think the Harley(Keihin) 44mm CV will be for the newly rebuilt, Weber should suffice on the old engine. I am just looking for recommendations based on experiences and some guidance/recommendations for battling rust on these little jeeps.
Daletec is offline   Reply With Quote Quick reply to this message
Old 03-17-2010, 10:21 AM   #2 (permalink)
I also meant to add that I have bookmarked Ack's FAQ site, tons of great info in there!!! I'll try to post up some before pics and track progress, here.
Old 03-17-2010, 10:39 AM   #3 (permalink)
Awesome! I have welder envy... so that's really cool in my book that you have the option of fabricating stuff for your rig. Pretty much all my stuff is bolt on.
Unless you're rock crawling or driving on soft sand, you don't need a wide tire. The 9.5 or 10.5 wide will give you better preformance on-road and on logging trails. A 30" tall tire will be good for your application and the 2 inch lift. With a 30" tire you won't need to worry too much about power. A lower gear transfer case will do you a world of difference with larger tires on-road and off road, but with 30's you wouldn't need to go too extreme. The GRS2 seems to be a good T-case for mild wheeling and it gives you freeway use of your 5th gear with the bigger tires.
For a good riding lift for your needs I would recommend the YJ spring conversion with spring UNDER axel. Spring over gives you more lift but not as much stability. If you only need a couple inches then the Spring under YJ is the way to go and your rig will handle even better than mine.
There are a couple places that sell hard tops but they're about $850-$1000. (plus about $200 shippng) I see them used on ebay once in a while but never in my neck of the woods A roll cage is a good investment if you got kids in the back. I've never rolled mine, but if I do I know they won't be crushed. I stay on the trails so I don't bother with an exo-cage. Nothing really to wrap my rig around...
good bumper and sliders for the occasion you stray from the trail... it happens.
Winch for pulling jeeps out of trouble... it happens.
The thorely headders are a great investment and will help you get more preformance with everything from the stock carb to the CV carb.
Great projects lined up! welcome to the forums!
Old 03-17-2010, 05:46 PM   #4 (permalink)
Thanks for the kind welcome!
The Weber arrived today. I do not have an aftermarket fuel pump nor a fuel pressure regulator, I will seek the advice at the local Advance Auto store, guy there has a rock crawler buggy, Toyota based, but he knows a fellow with a Sammy. Anyway, need to test the pressure and regulate it to 3.5 PSI as per the instructions. Upon close inspection under the hood, I realized that the previous owner has omitted several vacuum lines with two serious leaks at the intake manifold(no lines, open nipples sucking air). I will read the vacuum line routing and replace, I have purchased 10 feet of line to replace all with new, anyway. On with the project, pics coming this weekend.
Old 03-17-2010, 06:25 PM   #5 (permalink)
Found a second vacuum leak, open nipple in the intake. I am looking through Ack's FAQs, damn what a wealth of information!!! I may not have to post a question other than opinion, at all! Anyway, trying to find the correct routing from the section at Ack's, in the meantime, I used some new tubing, plugged it with a screw, had to adjust the idle as a result of these "corrections", will wait for the Weber install this weekend to replace the remainder vacuum lines with new and correct any routing errors! I hate when a shade-tree does stoopid things that we inherit and have to correct! It would be much easier to replace the lines if they were correct to begin with!!!
Old 03-17-2010, 07:45 PM   #6 (permalink)
if you have the samurai mechanical pump it's adequate for running the webber. I had a quad mikuni setup and the mechanical pump did fine on it. Any fuel your carb doesn't use the pump sends back to the tank through the bypass fuel return.
with the webber most of those vacuum lines will be capped off. acks faq has saved my bacon many times when sorting out vacuum lines.
Old 03-21-2010, 11:18 AM   #7 (permalink)
Got the Weber 34/34 installed and tuned. I would never have believed the difference that simply a carburetor can make, this thing will run with highway traffic and goes up hill at the speed limit!!! I did have to do quite a bit of fabrication to install the carb. The gaskets that come in the kit need to be trimmed to match the adapters and not restrict the flow and cause pooling in the intake. It did make an incredible difference in the mid-range performance. Installed the new black top to keep water out, it also looks better. Gonna install the stereo this week. I'll order a header and have new exhaust installed this next weekend. I also replaced the alternator belt. I am now investigating installing an electric fan in lieu of the clutch fan. My shift sheet/bolt kit has not yet arrived from Petroworks. I'll install that as soon as it arrives, too.
Old 03-21-2010, 02:21 PM   #8 (permalink)
Gallery: 4
NMHighPlains is on a distinguished road
You've been busy!!! I got my '87 a month or so ago, but I've been really watching the $$$ flow on this as I want to get it done for $3000, total.
Keep us posted. I especially want to know what kind of mileage you get from the carb.
NMHighPlains is offline   Reply With Quote Quick reply to this message
Old 03-21-2010, 06:56 PM   #9 (permalink)
wrenchwoman's Avatar
Where are you ordering your Thorley from? I ordered mine a month ago and am still waiting because apparently they're switching the header from chrome to ceramic coated and I guess they're behind. Just curious if you get yours before I get mine, I'll cancel my order and get it from wherever you order yours. And if you get your welding and rust taken care of, I'd pay you to do mine! How far is Lenoir from Culpeper, VA? :-)
Old 03-21-2010, 09:24 PM   #10 (permalink)
I will most likely order from Summit Racing, best price and great reputation for customer service. I don't want nor need chrome, I don't mind repainting as a part of maintenance. I barely have time for my project with my work schedule and family activities. I am an amateur welder at best, I would not feel comfortable welding someone else's vehicle. Mapquest shows 331 miles from Lenoir, NC to Culpeper, VA.
