Alignment 101 - Suzuki Forums: Suzuki Forum Site
Old 03-11-2010, 10:54 PM   #1 (permalink)
mulerider's Avatar
mulerider is on a distinguished road
Question Alignment 101
Does anyone know the stock specs for the 91 Sammy......caster, camber, and toe-in?
mulerider is offline   Reply With Quote Quick reply to this message
Old 03-12-2010, 04:21 AM   #2 (permalink)
hoping this is right, found it while looking for something else
Toe in: 0.08-0.24 inch
Caster angle 3 30'
King pin angle 9 00'
^^ direct from this site:
Suzuki Samurai Specifications
hope that helps...
Old 03-12-2010, 07:21 AM   #3 (permalink)
that sounds right.
Bill
in old El Paso...
Old 03-12-2010, 01:45 PM   #4 (permalink)
mulerider's Avatar
Thanks guys......I'm gonna try to tame the little varmint !!!
Old 03-12-2010, 10:15 PM   #5 (permalink)
mulerider's Avatar
Unhappy
Ack's faqs had this on the subject.
caster......... + 3.5 degree (+/- 1 deg.)
camber ...... + 1 degree (+/- .75 deg.)
toe-in ......... 2-6 mm. (.08 - .24 in.)
My camber is in spec but the caster is - 4.1 and the toe-in is .40 in.
I'll order some 7 degree wedges, back off the toe in , and see how it goes.
John
Old 03-15-2010, 10:43 PM   #6 (permalink)
ack
ack's Avatar
John
Thanks for stopping by Ack's FAQ!
-4 degrees is seriously off!
Did you measure caster on the top of the kingpin plate with the vehicle on perfectly level ground?
Wedges are the Devil's Spawn! The can corrode, break and generally do a [email protected] job. Your best bet (I assume that you have a SPOA lift) is to cut and reweld the perches.
I hope that this helps!
- Ack
'14 Ford Transit Connect DD
Old 03-15-2010, 10:49 PM   #7 (permalink)
You tell 'em Ack!
Wedges are da debil!
Bill
in old El Paso...
Old 03-16-2010, 09:25 PM   #8 (permalink)
mulerider's Avatar
-4 deSrees is seriously off!
Hey Ack....thanks for the encouragement and info.
Yes....my new aquisition does have a SPOA lift, 84 Toyota axles and 33'' super sw. tsl's.
I dropped the front axle and found 5 deg. wedges on the perches.......BACKWARDS !! I removed them and got a almost neutral caster. I have a fastrax cast/camb guage that works pretty good. I don't work as good as the guage though as I missed my mark of rewelded perches at +4.5. They turned out equal at slightly over +3 deg. (no wedges)
Driveshaft didn't suffer any at the slightly steeper angle.
My wife followed me in the minivan and flashed the lights when I hit 60 on the blacktop ( I was reading 67). Steers great, centers after a curve when you let the wheel slide through your hands. I'm thinking it's good enough and may get a little better with less agressive tires. It sounded like a "air- raid siren" !!!
Thank again Ack. I really appreciate your FAQ's site. Helped me a bunch!
John
Old 03-17-2010, 02:36 AM   #9 (permalink)
yeah, some people think if you point the dif at the transfer case it will make it drive better since the drive shaft isn't kinked as much.... doesn't work that way though...
Wedges are a great way to experiment with your setup and find out how much andusting you need to do, but they aren't a permanent solution. Glad you got them outa there. Some people run them all the time... I prefer not to.
Now that you got the angles straightened out... what kind of steering set up are you running?
