tyre brands - Suzuki Forums: Suzuki Forum Site
Old 03-07-2010, 05:16 AM   #1 (permalink)
Default tyre brands
im looking at getting bigger tyres (finally!) and was hoping to book it in for sometime this week. hoping to get 31x10.5's on it. has 2" lift, so should be enough, but will have to remove my sidesteps til i can shorten them a little.
what i want to know is what brands everyone uses?... im looking at the BFG M/T because i love the A/Ts. they grip so well and the rubber is cracking from age before the tread wore off... also, will that size be ok on the stock rims? cant afford that big if i have to buy rims also, im on a budget...
Old 03-08-2010, 02:20 AM   #2 (permalink)
ok i spoke to the local tyre retailers, they reckon that the 31's will go on the stock rims, but its recommended not to. id prefer to have a set of "road tires" and a set of "play tires" anyway so i dont wear the tread down, and for only $90 each for 15x8 rims its within my budget. but next question is will i need them offset? or will the 31's be fine without too much rubbing?
Old 03-08-2010, 01:43 PM   #3 (permalink)
Gallery: 8
You didn't specify Samurai or Sidekick. A 2" lift might not be quite enough for 31" tires on a Samurai, but might be OK on a Sidekick. Backspacing requirements are different as well.
31's are most often 10.5" wide. Typically, the tire manufacturer specifies a rim width that is about 2" narrower than the section width (sometimes up to 3"). This information is on their website. For example, my tire, the BFG T/A KO, in 31x10.5R15 calls for a 7-9" rim and is measured at an 8.5" rim width. That makes the 8" width near perfect for this tire. The OEM Suzuki rim, at 5.5", is really too narrow.
The T/A 30x9.5R15 is about a 9.5" tire and fits inside the (Samurai) fender flares. My Samurai spends a lot of time on the pavement in Calif, where you could be cited (but rarely happens) if the tires protrude. This tire is spec'd for 6.5 - 8.5" rims and fits nicely on 7" rims, as does the 235/75R15 which is almost as large.
The smaller sizes are better for driving on asphalt -- both the tire and wheel are lighter. If you need 8" rims, WheelersOffRoad has "15X8 BLACK Steel Wheel , 2.5" BS for $59/ea". There are other suppliers around as well, both Petroworks and Bart come to mind.
Old 03-08-2010, 04:06 PM   #4 (permalink)
I ran 9.5's on my stock rims for a while. If I remember right, I had to flip the rim so that it didn't rub when I turned it to the stops.
When I went up to a 10.5 I had to put wheel spacers in. Then I went up to a 33-12.5 and had to get a wider rim. I think they're 8" and the 12.5's looked like doughnuts on them. I'm back down to a 31-11.5 and they're just right on the 8" rims with 2.5" BS
Old 03-08-2010, 06:02 PM   #5 (permalink)
che_guitarra is on a distinguished road
BFG's are around $250 a pop to fit a standard height Sierra. Mine are starting to crack too, even though they've got a mountain of tread left.
Generic brands same siza as my BFG's start from around $150 a pop.
If you've got the option go to a Goodyear tire centre, they've for a 'buy 3 and the fourth is free' deal at the moment.
che_guitarra is offline   Reply With Quote Quick reply to this message
Old 03-08-2010, 06:05 PM   #6 (permalink)
hybrid510 is on a distinguished road
hello all.my question is about backspace.. what is 2.5 backspace in MM when i go to tire web sites it is MM Like +24 or +36 ,- 18 thanks
hybrid510 is offline   Reply With Quote Quick reply to this message
Old 03-09-2010, 08:48 PM   #7 (permalink)
chevy4x48586 is on a distinguished road
I don't think that 31 10.5"s will fly with only 2" of lift. I have mine on the stock rims and they are fine, but they do rub on the springs when i turn all the way left or right. I have a spoa lift with 2" lift shackels and thay rub. Also I dont know what you are looking for in tires but i got mine at walmart they are a good year authority. They are great in the mud and it only cost me about $610 mounted balanced and everything. But if your looking at more of a mud tire look into the Kumho Road Venture MT KL71. I have them on my silverado and they are amazing. Just a lil info from my travels.
chevy4x48586 is offline   Reply With Quote Quick reply to this message
Old 03-10-2010, 03:08 AM   #8 (permalink)
ok well ive decided to get new rims with it to stay on the safe side, but mainly so i can keep the muddies for play and not wear them down too quickly, and keep stock rims for stock sized H/T tires for through town efficiency.
will 15x8's make a difference with the rubbing? it have a 2" lift and front springs are less than 5 months old. or will i have to go for an offset rim...? if so, how much?
Old 03-11-2010, 06:50 PM   #9 (permalink)
The wider the rim won't matter if the offset doesn't change. When you get offset rims thats what moves the tires away from the rim. Even a 12" wide rim with factory offset would rub.
Old 03-11-2010, 10:33 PM   #10 (permalink)
I run the common steel 8x15's on both street and trail rigs, but I also run 1" spacers/adapters to offset the rims to keep from rubbing. Offset rims are pricey, and I have destroyed my share of wheels on these trails. I would rather spend $38 each instead of $120 each time I screw up. Initial outlay for the Spidertrax adapters is about $100 for each axle, but you only have to buy them once.
Bill
in old El Paso...
