1987 Samurai trany problem - Suzuki Forums: Suzuki Forum Site
Old 02-20-2010, 10:21 PM   #1 (permalink)
VIRGOPELO is on a distinguished road
Question 1987 Samurai trany problem
Hi to all i have a problem with my transmision it gring in almost al gears specialy from first to second if i chance fast ,I re-built this trany because i have this problem before and i change the bearings and syn cross and put a new cloche but the problem remain the same ,any ideas or shuld i buy another trany
thanks
VIRGOPELO is offline   Reply With Quote Quick reply to this message
Old 02-22-2010, 12:32 AM   #2 (permalink)
grand_sea is on a distinguished road
Originally Posted by VIRGOPELO View Post
Hi to all i have a problem with my transmission it is grinding in all most all gears, especially from first to second if i change fast ,I re-built this tranny because I had this problem before so I changed the bearings and syncro's and put in a new clutch, but the problem remains the same ,any ideas or should i buy another tranny
thanks
and what vehicle is this on...not sure about answering if you need a new tranny but depending on where you are and what you are driving I may have a tranny!
So wait for the experienced guys to answer your question and in the meantime let us know what your driving and a city or at least a state, and you may get better responses if you spell check I think this is what your trying to say(not picking on you just trying to help!)
grand_sea is offline   Reply With Quote Quick reply to this message
Old 02-22-2010, 04:57 AM   #3 (permalink)
He's got an 87 samurai and lives in Miami FL.
If you've rebuilt it and it's still doing the same thing then it's most likely something like a bent control shaft or something that is going to require another complete removal and dissasembly just to find it. Once the problem is located, you will need a donor transmission for the replacement part since the problem wasn't one of the pieces available in the rebuild kits. I think you'd be better off just replacing it with a rebuilt unit. They can cost anywhere from a hundred bucks at a wrecking yard, to 800 bucks from a transmission rebuilder.
Old 02-22-2010, 05:09 AM   #4 (permalink)
darn I have a tranny that came with my engine I bought them both for $200 of craigslist. But I am in Colorado Springs Colorado so I'm sure that after shipping he could get a tranny shop to rebuild it for the same price...that being said I would check craigslist and e-bay along with the local tranny shops and junkyards!
Old 02-22-2010, 09:44 AM   #5 (permalink)
Silly question...
Is the clutch adjusted to where you have full release before the pedal hits the floor?
If so, then nevermind - as said above the problem could be something else inside that wasn't replaced in the rebuild. But if the pedal hits the floor it could just be a clutch adjustment.
Old 02-22-2010, 10:46 AM   #6 (permalink)
I sometimes overlook the obvious things don't I? The worst part is I just recently had to readjust my clutch because it wasn't disengaging all the way and started to grind the gears when I shifted. Problem was from when I installed a new clutch cable, I didn't adjust it properly.
Old 02-22-2010, 04:26 PM   #7 (permalink)
Question
Would this cause mine to sound like it's grinding(checked the gearbox no shavings, checked the tranny no shavings) when I put it in 5th as soon as I let off the clutch it's like it's not engaging fully!
I drive an '87 samurai!
Old 02-22-2010, 04:32 PM   #8 (permalink)
If it was the clutch, it would grind in all of the gears. If it is hard to get it into gear - Syncho's. If it grinds after gear has been acheived - gears...
Old 02-22-2010, 05:26 PM   #9 (permalink)
Thumbs up
Well, guess I won't be putting that spare tranny on E-bay!! Thank you Bill for making sense once again!
Old 02-24-2010, 05:01 PM   #10 (permalink)
Hi and thanks to all for the replays
I live in Miami Floria and i driving most of the time on road and let me tell you guys my history I put a exedy clutch new a few Months a go and i dont remember but probably the gear were like this since i get the car ,i get this car to make a full restoration because it was in not working condition and i re built the engine install power steering from one honda passport and i painted and put new tires and spacer and is a great looking little car but i felt that the gears where grinding a bit so i start to play with the clutch and was the same actually i felt that the exedy clutch has to much grip so i get the oem suzuki disck and clutch (more expensive )but nice and still have the same problem so i rebult the tranny whit the regular kit (bearings seals and syncros )) but i have stiil the same problem so i think that my best bet is to get another tranny but this cars and parts are very hard to found in miami so i will stare to look around ebay
if you have any other idea please let me know and i an sorry for replay to you guys so late but i was with out internet for 3 days
thanks to all
