tire questions... - Suzuki Forums: Suzuki Forum Site
Old 02-17-2010, 12:46 PM   #1 (permalink)
redbike22 is on a distinguished road
Default tire questions...
ok, i just got an 88 sammi with a 90 rebuilt motor--fuel inj. 4 cyl. right now it is running great with 33" bf goodrich mud terrain tires on it. one of the tires has a very slow leak at the rim so i want to replace it. my questions are:
-can i put a mismatched 33" tire on it for now to get by until i can get 4 new ones
-do you think the 33's are too much on the motor and should i go down a couple sizes?
thanks!!!
redbike22 is offline   Reply With Quote Quick reply to this message
Old 02-17-2010, 02:03 PM   #2 (permalink)
If the acceleration isn't sluggish right now, then the previousowner mayhave already swapped the gearing to make up for the 33's.
You can run a mismatched set in an emergency, but I wouldn't do it for long. Also, don't put it in 4wd, if the tire height is too different (actual size, not just numbers on the side) then you will have binding problems.
Old 02-17-2010, 04:47 PM   #3 (permalink)
ok, great. thank you! as far as it being sluggish, it doesn't seem bad to me...? i once had an 85 ford ranger 4cyl. with 33's and it was terribly slow...this doesn't seem too bad. i just don't want to put too much strain on it.
Old 02-17-2010, 06:01 PM   #4 (permalink)
I would check the odometer next time you are going down the road against the markers, or use a gps...
that way you can tell if the gears have been changed...
thanks,
george
Old 02-17-2010, 06:25 PM   #5 (permalink)
I once ran a set of used tires that were 3 different brands. They were 33x12.50's and all about the same size and construction. 7ply all terrains. I ran those for about 6 years on freeway and on dirt before they started leaking because the rubber on the sidewall was so old and cracking. Samurai isn't heavy enough to actually wear down the tread of a tire if you have it even halfway aligned. The rubber will wear out before your treads in most cases, but you will get much better street preformance if your wheels aren't fighting each other. If you go with mismatched brands, at least try to get the dimensions the same. Currently I'm running the used tires of my old jeep that I sold... 4 years ago? They were 4 years old when I swapped them so these tires are 8 years old and I havn't worn down the tread on them any since they came off the jeep.
Old 02-17-2010, 07:09 PM   #6 (permalink)
Try wearing out swampers...
It ain't gonna happen!
Cracked sidewalls (like you said) will be the only reason to buy new shoes.
Old 02-18-2010, 10:10 AM   #7 (permalink)
my996duc1's Avatar
my996duc1 is on a distinguished road
I agree with everyone that you should be fine with mismatched tires but if you decide to run a locker at some point I would match the tires on the axle with the locker.
1987 Tintop
my996duc1 is offline   Reply With Quote Quick reply to this message
