Advice on this OME lift kit fromTrailTough? - Suzuki Forums: Suzuki Forum Site
LinkBack Thread Tools
Old 02-16-2010, 11:20 PM
born1988's Avatar
born1988 is on a distinguished road
Default Advice on this OME lift kit fromTrailTough?
I am looking to lift my '88 Samurai a few inches and improve the overall on/off-road capabilities. Any comments on the pros/cons of this lift kit? Suggest something better?
Old Man Emu Samurai Lift
Thanks in advance guys,
Matt
born1988 is offline   Quick reply to this message
Old 02-17-2010, 10:51 AM
it's a very mild lift for a lot of money. The OME springs are good quality, as are the Doestech shocks, but aren't for abusive use. If you just plan on doing some easy trail riding and on road driving they will provide the lift you need for 29" or 30" tires. The ride is not going to be AS rough as the stock springs, but it being a short spring, the OME spring will still be a pretty bumpy ride. There's not much way around that when using a short spring. If you ever get more hardcore with it and convert it to spring-over axle then you should put an anti-wrap bar on the back to keep the springs from snapping. lifted springs are tempered harder and they don't like to be bent the wrong way.
Baratacus is offline   Quick reply to this message
Old 02-17-2010, 11:22 AM
That kit has been out for awhile and is a proven kit. I think the 88.5 I got a few years back had that kit installed by the previous owner. Decent kit. Also easy to install in an afternoon.
Billjohn is offline   Quick reply to this message
Old 02-17-2010, 01:18 PM
born1988's Avatar
Thanks for the reply guys. I spend a lot of my driving on paved roads/highway, and the rest of the time on logging roads hunting. I dont need much of a lift, just need to replace the original shocks and springs, so a few inches is all i want.
The only other springs I have looked at are Deaver springs. If I get 3" deavers am I going to need anything other than the drop arm, and brake lines? Any comment on Deavers vs OME?? From my research I think I want to stay SPUA for less body roll on the road (articulation is not a big deal for my type of off-road driving, although clearance is nice). For the amount of money I will spend on this lift is there something bigger you would suggest SPUA? New to this...
Cheers
Old 02-17-2010, 06:32 PM
its all about the application, and for your application I think this kit would be great. If you keep it under 3" then you should be fine with just the springs, shocks, brake-lines, drop pitman, and the extended swaybar mount.
Old 02-17-2010, 07:07 PM
i currently use OME shocks, i think the back springs are too. no idea of how old they are, but i recently replaced the front springs after i massively bent one of them. i find that they are rather capable, but a lot rougher than the new springs i use now...
whincup is offline   Quick reply to this message
Old 02-18-2010, 05:06 PM
born1988's Avatar
If I add extended shackles to this lift will I need something better than the drop pittman arm to address steering? Are there any cons to extended shackles... say for another 1.5" of lift?
Cheers guys
Old 02-18-2010, 11:28 PM
making the camber angle steeper is going to make your steering more squirly. If you use a longer shackle, you will need to shim it or re-weld the perch in the proper position so the camber angle doesn't change. Putting a 2.5-3 inch lifted spring on it and then another 1.5 inches of shackle lift you could still use the drop pitman arm, but you may need a longer one than the one supplied in the kit you're looking at. Same with the sway bar extensions.
Old 09-09-2010, 03:48 PM
sickzuki's Avatar
sickzuki is on a distinguished road
I was going to do a home 2-Inch lift without a kit. But I have been offered a 2-Inch OME lift kit for $350 that is with postage from Sydney.. I am not sure exactly how good condition it is in but would this be worth buying?
sickzuki is offline   Quick reply to this message
Old 09-09-2010, 06:01 PM
was the Home lift you were going to do involving lift springs or were you just putting longer shackles on, or were you going to do a spring over axle lift?
Same questions regarding the OME lift and what are they including in the kit?
