TT yj wrangler conversion leaf springs - Suzuki Forums: Suzuki Forum Site
Old 02-15-2010, 10:57 AM   #1 (permalink)
c0card01 is on a distinguished road
Default TT yj wrangler conversion leaf springs
Hi just broke down and bought the wrangler conversion kit from trail tough looks like a pretty awsome kit. Now I am in the market for my springs. I want to run 33in tires on 15 in rim in the spring over setup. dont want to cut the fenders either. what brand and size lifted spring have you found to be the best, looking for smooth ride, no rubbing thinking of going with 10.50 or 12.50 tire? Also trying to keep cost low. Also noticing do i need yj front springs on front of sammy and yj rear on rear off sammy or does it matter?
Thanks anything will help\\
Colton
c0card01 is offline   Reply With Quote Quick reply to this message
Old 02-15-2010, 11:15 AM   #2 (permalink)
my996duc1's Avatar
my996duc1 is on a distinguished road
first thing I would do is search on some forums that are more geared towards this type of mod such as zuwharrie and zukikrawlers.
this forum is great for really simple questions and such but once you get into the bigger mods this forum isn't going to offer alot of answers.
Front and rear YJ springs are the same size just different number of leaf springs in the pack. Fronts a 4 pack and the rears are 5 pack. Depending on the weight of the vehicle you have you may want to run 5 pack on all four corners or even make your own combo of spring leafs to get you the height and ride that you are looking for.
lifted springs usually will not offer a "smooth" ride but I guess it is all in what you compare it too. I used stock springs to get a lifted spring and still have a "smooth" ride.
I am running heavy zuki with engine swap, heavy bumpers, winch, ect... so I was going with the 5 pack springs on all four corners but it didn't give me enough lift so I called Brent at Trail Tough and he suggested that I make my own 6-pack springs and those gave me another 1"+ of lift but still almost as soft as the regular 5 pack springs.
I found my YJ springs on craigslist for $60 a vehicle set. I ended up buying 8 springs or two car sets for $120 and then I had extras to make my own combo of leafs to get the ride and height that I wanted.
attached is a pic of mine on 31 -12.50 x 15 tires. I plan on swapping to 33 once these wear out and I have plenty of room for them. Also be sure to add some good frame mounted bumpstops, don't rely on the shock mounted ones. Some pictures are floating around of holes ripped in the frame because of the shock mounted bumpstops...
1987 Tintop
my996duc1 is offline   Reply With Quote Quick reply to this message
Old 02-15-2010, 12:46 PM   #3 (permalink)
k thanks I too will be runnin winch and bumpers
Old 02-15-2010, 02:48 PM   #4 (permalink)
YJ springs come in 3 flavors.
4 leaf - usually on front axle of factory soft tops
5 leaf - usually on rear axle of factory hard tops and front axle of factory soft tops
6 leaf - usually on rear axle of factory hard tops
I would also suggest 6 leaf packs for your 33's with bumpers and a winch.
I am running that setup with 6 leaf lifted springs (2") because of the spares I carry on the trail and it is smooth as glass in the rough stuff as long as you are aired down properly.
And if you don't want to run offset wheels or spacers stick with the 10.5" wide tires.
The problem with the shock bumpstops only happens when there is too little spring and too little up travel and shocks that are not valved correctly for the weight of the vehicle... - personal experiance, BTDT.
Oh... there are folks here with a bit of experiance that do more than the 'simple' answers...
Old 02-15-2010, 08:17 PM   #5 (permalink)
Talked to trail tough I was wanting to run 2 in lifted springs but they told me i would have driveline issues and to go 5 leaf all four corners and should have plenty of room for 33's however i believe i talked to you before about the kit and if i remember didnt you say that you had rubbing issues and had to do a body lift of something with stock arched leaf springs?
Old 02-15-2010, 08:50 PM   #6 (permalink)
I use taller than stock front spacers at the front of the hood to raise the hood a little for the 1.6ltr but I don't use any kind of full body lift. I went to lifted springs when I had too much articulation and had some rubbing at the fenders. That is with 33x12.50's
Anything taller than a 3" lift will have driveline issues. I don't recommend stock drivelines on any trail vehicle that might see a rock or drive under the influence of a heavy foot...
Old 02-16-2010, 01:06 PM   #7 (permalink)
so with the trail tough wrangler conversion kit the $1300 one and 2in lifted leafs all the way around i will not have any issues? no rubbing of tire on anything and enough driveline spacing with the two spacers provided as well as the extended yoke? Also will the shocks they supplied with the kit have enough travel
Old 02-16-2010, 07:13 PM   #8 (permalink)
my996duc1's Avatar
Call Trail Tough... they designed the kit and know exactly how it works as far as what spacers are needed, ect... The kit was designed for stock YJ springs NOT lifted springs, so it may need some other parts to make it complete. I would call and ask.
They are always super friendly and always eager to answer your questions. They have never been pushy to sell parts and always nice on the phone.
With 60+ views and only two people responding, I will stand with my original statement about the majority people on this forum not being able to answer anything other than simple questions.... Billjohn and ACK are the exception to this rule
1987 Tintop
Old 02-17-2010, 10:27 AM   #9 (permalink)
considering there's 8 posts in this topic and people check up on it every time it updates... I know I do. That means you have 8 people watching this topic, 4 of them have posted in this topic. That doesn't account for people who hit this topic from a search engine that links when they search for Samurai YJ spring conversion...
There's really not a whole lot more to add that you and Bill havn't covered already. Going to those other sites you're a lot more apt to get 4 or 5 conflicting responses from people who havn't done the lift but have an opinion on it, or people who set it up wrong, or someone who's running a completely hybrid suspension and trying to compare his Yota's with 38" mudders to someone with a stocker on 33's.
On here no one assumes you should know anything, and there are quite a few knowledgeable members who will give you the information you need without a load of crap to make you feel stupid. If they can't answer the questions they can point you to where you can get answers, but I havn't seen many questions on here that couldn't be answered by our members.
Old 02-21-2010, 09:48 PM   #10 (permalink)
thanks yall have been a lot of help, I found a set of springs they are 4 leaf fronts and 5 leaf rear started installing the kit this weekend.
only problems I see with the kit so far are the shock towers, They seem a little too tall and the bottom angled part of the tower needs a little more bend to it, what can I expect though its ford parts lol.
When Its done will post some pictures in this listing and let yall know how it turned out
Thanks,
Colton
