fuel pump - Suzuki Forums: Suzuki Forum Site
Old 12-06-2009, 07:39 PM   #1 (permalink)
bcarter5's Avatar
bcarter5 is on a distinguished road
Default fuel pump
If I Replace My Old Mech.fuel Pump On A 1988 Samurai With An Electric Fuel Pump.can I Leave The Old One On And Block Off All The Ports Or Do I Need To Remove It
bcarter5 is offline   Reply With Quote Quick reply to this message
Old 12-06-2009, 11:44 PM   #2 (permalink)
ack
ack's Avatar
Default mechanical fuel pump..
The best way to disable the mechanical fuel pump is to replace it with a plate. This plate could be easily fashioned out of a piece of flat aluminum or steel (aluminum would be better) cut to size with a grinder. You can use the pump as a template to drill two mounting holes. seal it with form-a-gasket.
You could remove the acutating rod but that might cause oil to pass though the acutating rod's passageway and drain out the breather tube.
Just removing the hoses will create a waste of energy as the camshaft will still be driving the pump although no fuel will be moving through it.
I hope that this helps!
- Ack
Ack's FAQ
'14 Ford Transit Connect DD
Old 12-07-2009, 06:07 AM   #3 (permalink)
bcarter5's Avatar
thanks ack im sure i will have lots more questions
