Runs good....for 10 minutes! - Suzuki Forums: Suzuki Forum Site
Old 11-19-2009, 11:14 PM   #1 (permalink)
Sammie18 is on a distinguished road
Default Runs good....for 10 minutes!
Well i thought that my alternator was my problem cause my battery was going dead overnight!But come to find out,whenever i drive my 87' Samurai it runs great for about 10 minutes then it just seems to bog down and shuts off..if i wait for about 5 to 10 minutes its starts right back up and runs for another 10 minutes and shuts off!It continues the process over and over,can anyone help me with my problem please!?
Sammie18 is offline   Reply With Quote Quick reply to this message
Old 11-20-2009, 06:19 AM   #2 (permalink)
if its pretty consistant that way it sounds like a fuel or an air restriction. It could be caused by the coil heating up though. Have you done any work on it recently other than the alternator? When's the last time the fuel filter was changed? did it used to do the choking out thing before you changed the alternator?
Old 11-20-2009, 07:49 AM   #3 (permalink)
Yes it choked out before the alternator and i thought that was the problem but it wasn't unfortunatly,I changed the fuel filter as well and i'm still havin the same problems!
Old 11-20-2009, 09:36 AM   #4 (permalink)
does it do it when sitting at idle or just under load? Did you check the vapor return line to make sure it's hooked up correctly? (Deja-vu... I think I just posed this question to someone else a couple days ago)
Originally Posted by Baratacus View Post
I have a samurai so I don't know a lot about your fuel tank or how similar or different it is from mine. I do know that a lot of people don't hook up their vapor return line properly or it gets plugged by debris. When this happens, a vacuum forms in the tank as the engine draws fuel out of it. If air can not enter the tank through the vent on the vapor return line the vacuum pressure overcomes the pumps ability to draw fuel. When you shut the engine down, the tank will equalize pressure since the engine is no longer sucking fuel out of it. Try taking your gas cap off and see if it still has the problem. If removing the gas cap works, then you need to find out where in the venting system it's plugged.
man I love the copy paste function!
Bram and Murphy in that topic both had similar problems... turns out neither was a vacuum draw on the tank though. If taking the cap off doesn't work, then you might follow that topic and see if they find resolutions to their issue.
Old 11-20-2009, 12:10 PM   #5 (permalink)
It does it when its under a load basically,it seems like when it gets good and warmed up about 10 minutes into a ride it just starts bogging down and shuts off,almost like its running out of gas.
