Longer Lug Nut Bolts - Suzuki Forums: Suzuki Forum Site
Old 09-06-2009, 06:13 PM   #1 (permalink)
Roody is on a distinguished road
Default Longer Lug Nut Bolts
i have a set of older style ford aluminum rims. but because they are so thick where you bolt them on i need longer lug nut bolts. does anyone know where i can order these? or is it safe to drill the hole's in the rim out half way down so that my lug nuts fit in.
Roody is offline   Reply With Quote Quick reply to this message
Old 09-06-2009, 06:31 PM   #2 (permalink)
It would be safer to replace the wheel studs. Check tuner shops. Some racing organizations require longer wheel studs.
Old 09-07-2009, 07:53 PM   #3 (permalink)
has anyone tried to use lug nut bolts and studs from older style ford's? since my rims are from a ford i figured if i could i would use the hardware too.
Old 09-08-2009, 03:27 PM   #4 (permalink)
Gallery: 8
Much Safer to replace the wheel studs!
Sidekick wheel studs are said to be longer and fronts vs rears are different/longer as well. Samurais (Suzukis) use a 12x1.25 stud and the OEM/aftermarket steel wheels take a 60 cone seat lug nut. Some alloy wheels may take a different style of lug nut & seat (but I don't own any alloy wheels) -- something to check.
The Costco near me now sells replacement lug nuts and has the Gorilla Heat Treated 4113?HT, stamped "12mm1.25HT" for under a buck apiece. They're the same 3/4" (19mm) size as OEM and take the same lug wrench. If you're ever gonna use chrome rims, or just want the toughest lug nut around, these are the ones for me. The "bulge" style keeps the wrench from scraping the rim. I bought a couple/three extras for trail spares.
Old 09-08-2009, 08:13 PM   #5 (permalink)
are those longer tho? i have aluminum rims which are about an inch thick at the bolt pattern so i need the length.
Old 09-20-2009, 11:33 PM   #6 (permalink)
mxwedge426 is on a distinguished road
Default lug nutz
don't know if you've figured it out yet but you can walk into any auto parts store and tell them what you've got and what you want and they should be able to order it if they don't have it on the shelf!
mxwedge426 is offline   Reply With Quote Quick reply to this message
