Sami only clicks - Suzuki Forums: Suzuki Forum Site
Old 08-23-2009, 02:15 PM   #1 (permalink)
Sammy1987 is on a distinguished road
Default Sami only clicks
I just Acquired a free samurai but the only quirk is that it does not run... I put a battery in it. New 4 gauge battery terminals for both postive and negative. I have full interior power and as well as lights and radio. When i turn the key with the clutch in the starter only clicks. The motor is not seized. I pulled the starter and took it to the local auto parts store and they said it had a bad solonoid. 80 bucks later and a reman starter and it still clicks. I searched and found the sammy starter click fix. Did this with a fuse and relay. still nothin... What could be wrong? Does anyone have any ideas? Help is appreciated!! Thanks
Ken
Sammy1987 is offline   Reply With Quote Quick reply to this message
Old 08-23-2009, 06:20 PM   #2 (permalink)
I'd start with a known new / good battery, and double check your battery connections INCLUDING where they ultimately tie in to. Any and all engine and battery GROUND connections are super important too as far as having good contact.
Checking each and every FUSE is not a bad idea either on a vehicle just acquired, and you are trying to rid any demons.
Old 08-23-2009, 08:24 PM   #3 (permalink)
lumpylarry's Avatar
have you tried turning the engine by hand? make sure its not seized..
2008 suzuki SX4 sport sedan 5spd FWD
2007 suzuki boulevard C50 SE
2001 suzuki swift 1.3 5spd blue
Old 08-23-2009, 08:44 PM   #4 (permalink)
I hear ya' Larry, but he says
Sammy. One other thing you can try is to by-pass all starter control circuit wires and components by using a jumper wire (12+ off the battery) directly to the light gauge wire (spade) post on the solenoid. Make sure you've got her out of gear before you try it though.
Old 08-23-2009, 08:46 PM   #5 (permalink)
lumpylarry's Avatar
oops.. missed that...
Old 08-24-2009, 09:11 AM   #6 (permalink)
Also check the heavy white wire that goes to the positive terminal on the battery. It is a fusable link, so it may LOOK normal but could still be fried inside.
Also, see if adding a new ground strap from frame to engine helps...
There is a small (too small in my opinion) wire at the firewall almost behind the battery that acts as a ground strap. It is easy to miss. When the engine can't find a decent ground it will use the clutch cable as a ground. This will eventually lead to the shielding melting and the clutch cable failing.
Old 08-24-2009, 09:54 AM   #7 (permalink)
Gallery: 8
Lots of things to check. I'm thinking that the fusible link is OK 'cause you have radio power but, here it is anyway.
On my rig it's a short green wire. When installing a larger alternator, it's commonly and easily overloaded when charging a low battery and gets blown open, but it's hard to tell by looking, until you tug on the ends and they readily pull apart ('cause the wire inside is blown).
You can easily check voltages with an inexpensive voltmeter like HarborFreight items #90899 or #92020, often on sale. When you turn the key to start, the voltage at the starter solenoid-to-its-case should be about the same as the battery. If you have a bad ground strap somewhere, you'll see the voltage drop a lot, so much that the starter cannot crank, and just clicks. The ground straps are exposed somewhat and susceptible to corrosion and physical damage.
Old 08-24-2009, 10:24 AM   #8 (permalink)
Well i tested the motor by placing a ratchet on the crank. the mtor turns over fine. All fuses are good. I assume the fusible link is good because i have power. if it was blown i would assume there would be no power. I see no ground straps except the negative on the battery. I will try to add a nice 4 gauge from some old amp wire. I tried to over ride the ignition to only get the same clicking from the solonoid. The only thing i can think of is to push start it. The sammi has sat for many months so i hate to do that. The reman starter might be bad so i will have it tested. There is a cable that looks like a throttle cable coming from the firewall that it not attached to anything. I thought it was for the throttle or cruise. but the throttle is hooked up and it has no cruise. Any help? I will look in the haynes book. Thanks for all help here guys! I hope she will start soon.
Ken
Old 08-24-2009, 10:41 AM   #9 (permalink)
Look at the battery where it meets the firewall. Pull the battery away a little and you will see a small screw that grounds the wire at the firewall. It is near the right/top corner (away from the fender) of the battery. In this old pic you can see it with a blue wire attached just above the battery.
The other 'throttle' cable could be one of two things. It the previous owner had a thumb throttle installed on the shifter, he/she may have left the cable there after removing it.
It could also be a manual choke. From the factory, our zooks have a water choke, but sometimes when folks install a weber that doesn't have a water choke, or a CV carb it needs a manual choke cable run back to the dash.
Old 08-24-2009, 11:12 AM   #10 (permalink)
On a Sammi, does the NEG battery cable attach to the engine?
If not, yeah...do the new engine ground cable thing.
You can do the same thing if you connect a jumper cable from the battery NEG to clean metal (ground) on the engine proper. Better yet, right to the starter case.
If THAT fails, then ya', with all you've tried thus far, you've got a starter or solenoid issue still (if the battery is good)!
