tie rod ends on top - Suzuki Forums: Suzuki Forum Site
Old 08-12-2009, 02:55 PM   #1 (permalink)
87samurai_dunn is on a distinguished road
Default tie rod ends on top
if i do a regular lift without spoa can i move the outer tie rod ends to the top of the ball joint piece? all my clearances look good, it just looks like i would have to modify the dust shield for the brakes. does anybody know of any problems with this?
87samurai_dunn is offline   Reply With Quote Quick reply to this message
Old 08-12-2009, 03:15 PM   #2 (permalink)
The tie rod end is actually tapered, so unless you drill it and then use a tapered metal bushing inside to come in from the top it isn't going to work.
Old 08-12-2009, 04:13 PM   #3 (permalink)
would it be worth it to put it up a little more or would it be a waist of time?
Old 08-12-2009, 04:48 PM   #4 (permalink)
Usually a SPUA doesn't require much steering adjustment. If the offset is only 3" then i would suggest a dropped pitman arm (I was saying 2" earlier but I misspoke).
But if you are going big, it would be less of a hassle to just move the drag link.
Stage One OTS kit:
LOW RANGE OFFROAD
or OTT Stage One kit:
(ask for 'flat arm' for SPUA, depending on the size of the lift)
Knuckle over, High-steer steering system for the Samurai.
Old 08-13-2009, 12:02 AM   #5 (permalink)
well im going with 3 inch lift springs on top of the shackle reverse that brought it up 2 inches so i was seeing if it would be easier to do it that way but it seems not... would just the drop pitman arm be enough or would i have to do ott steering on that? and i put a 2 inch body lift on so will i be able to run 31s pretty easily once the lift springs are on?
Old 08-13-2009, 08:25 AM   #6 (permalink)
The dropped pitman arm is designed for a 3" lift. You will be at 5" with what you outlined above (the body lift doesn't count for steering as the steering box is mounted to the frame). I would just go with an OTS/OTT system designed for a 5" lift.
By the way, with that suspension lift, you can remove the body lift. 31's will fit easily. I have my opinions about body lifts. Let's suffice it to say that unless you are using the lift to aid in an engine conversion where you need the clearance at the tunnel or hood - just say no...
Old 08-13-2009, 12:48 PM   #7 (permalink)
alright...i thank you very much...the body lift was free so i put it on but i dont really like it much anyways so i will take it off
