'nother tranny question - Suzuki Forums: Suzuki Forum Site
Old 02-11-2009, 12:03 PM   #1 (permalink)
Phils is on a distinguished road
Default 'nother tranny question
I didn't want to hijack zerez's thread but it reminded me of something about my transmission that I've never seen with other cars before. BillJohn linked to his instructions for rebuilding the transmission and I've bookmarked it for the future.
When the tranny is in neutral and the clutch is let out, the Zuki "tries" to go forward. It doesn't, but you can feel it trying. If the transfer case is in Neutral, the driveshaft from tranny to t-case spins with engine RPM even tho the tranny is in neutral too.
Before I did some carb adjustments, letting the clutch out in neutral would put enough load on the engine that when cold, it'd die. In neutral, it shouldn't put much load on the engine at all.
Is this normal? Or a problem 'on the horizon'?
Phil
Phils is offline   Reply With Quote Quick reply to this message
Old 02-11-2009, 12:16 PM   #2 (permalink)
Pilsner Pig's Avatar
Gallery: 3
Pilsner Pig is on a distinguished road
I have the exact same problem and I have to leave my transfercase in neutral to let it warm up on these cold mornings.
Hopefully someone can help us!
Pilsner Pig is offline   Reply With Quote Quick reply to this message
Old 02-11-2009, 12:41 PM   #3 (permalink)
It is normal for the driveshaft to spin when in neutral. Although the gear is not engaged, the friction on the mainshaft will still try to spin the gear. In a perfect world, the lube would let the shaft spin freely...
Check your tranny oil and see if you need to change it. If the seals are good, you might want to try a synthetic to free it up a bit.
Old 02-11-2009, 12:42 PM   #4 (permalink)
Thanks again PP. The number of brews I owe you is beginning to reach the point where you'll have to come on down to Paradise so I can square up!
That this affects (at least) you too means to me that it's a somewhat "normal" thing.
Phil
Old 02-11-2009, 12:43 PM   #5 (permalink)
Oh, and if it has never been rebuilt (new bearings) you may want to try that. Remember it's a 20 year old vehicle...
Old 02-11-2009, 12:50 PM   #6 (permalink)
Thanks (as always) to you too again Bill.
I first noticed this right after buying the Zuki. While I was trying to find that knock (another thread), I wanted to eliminate transmission noise so I checked the oil level then, found it over 2 qts low, and refilled with synthetic (the only lubricants I use).
I could see where gear lube had been spraying out the rear seal all over the undercarriage. For our intended uses, that's a non-problem.
Phil
