1986 samurai front driveshaft is too short - Suzuki Forums: Suzuki Forum Site
Old 02-10-2009, 01:45 PM   #1 (permalink)
porttownsendzuki is on a distinguished road
Default 1986 samurai front driveshaft is too short
I have an 86 samurai 2wd model that i've been converting to 4wd. I put in the new transfer case, and a new spoa front axle. I bought a driveshaft off ebay, saying all driveshafts were the same. I went to bolt it in and its about 3 inches too short fully extended. The space between the differential flange and transfer case flang is 33".
Any suggestions?
porttownsendzuki is offline   Reply With Quote Quick reply to this message
Old 02-10-2009, 03:48 PM   #2 (permalink)
Are you sure you got a front driveshaft? The front driveshaft is longer than the rear.
Old 02-10-2009, 04:11 PM   #3 (permalink)
Pilsner Pig's Avatar
Gallery: 3
Pilsner Pig is on a distinguished road
I have driveshaft spacers that lengthen mine about 3". Check out any of the 'zuki stores, Rocky Road, Breeze industries, Calmini they are cheap and although not as good as a proper custom drive shaft I have never had any problems with mine with all the abuse I put mine through.
Driveshaft spacers for Suzuki
Pilsner Pig is offline   Reply With Quote Quick reply to this message
Old 02-10-2009, 05:37 PM   #4 (permalink)
yes, it is the Front driveshaft, for sure
Old 02-10-2009, 10:34 PM   #5 (permalink)
Diana29 is on a distinguished road
itz front drive shaft , man
Diana29 is offline   Reply With Quote Quick reply to this message
Old 02-11-2009, 10:01 AM   #6 (permalink)
3" is pretty much the maximum you want to extend using spacers... If it's your lift and/or you have moved the axle forward enough to require that much extension you should really consider ordering an aftermarket shaft (and consider longer spline travel). Or going to a longer Toyota shaft using Rat Adapters from Rock 4X Fabrication.
