Tire Size To Lift Info. - Suzuki Forums: Suzuki Forum Site
Old 11-21-2008, 11:00 PM   #1 (permalink)
Mike124 is on a distinguished road
Default Tire Size To Lift Info.
If your wondering how much lift you will need to fit those bigger tires, then this should help you choose.
(Information is not 100%, remember to ALWAYS test fit a tire for clearance)
Tire Size - Lift Size
215 (27") - Stock (no lift is needed)
29x9.5 - 1.5"
30x9.5 - 2"
31x10.5 - 3"-4" (Over 3" you need longer brake lines / Over 4" need drive shaft spacers or long drive shafts)
32x11.5 - 4"-5" (Spring Over Axle Setup is recommend for lifts Over 3" for comfort reason)
33x12.5 - 6"-7" (You might have to upgrade you stock axles for tires bigger the 32", Calmini sells Heavy-Duty 27 Spline axles for front & rear)
Bigger then 33's - 8"+
You can combine lifts to gain a pacific amount of lift without messing with drivetrain.
For example, you could do a 2" Leaf Spring Lift + 2" Body Lift For 4" with is enough for 32's.
You'd get enough lift for 32's an not have to install drive shaft spacers or longer brake lines.
Go To this page "Truth About Lifts" for more information on lift types.
Mike124
Mike124 is offline   Reply With Quote Quick reply to this message
Old 11-22-2008, 09:38 PM   #2 (permalink)
92_Kikr_4x4 is on a distinguished road
Thanks for posting this.
I'm thinking of lifting my kikr and putting a little bigger tires on it. I don't want a monster....but just a little bigger.
Thanks for the post.
92_Kikr_4x4 is offline   Reply With Quote Quick reply to this message
Old 11-22-2008, 09:48 PM   #3 (permalink)
Happy to help, check back in 30min or so, i'm adding more info to thread.
Old 11-22-2008, 09:53 PM   #4 (permalink)
Okay. Will do.
Old 11-23-2008, 09:58 PM   #5 (permalink)
clivey is on a distinguished road
You may also need offset rims or wheel spacers to prevent the bigger front tires from rubbing against the leaf springs during tight turns.
Fitting larger tires will adversely affect your gearing and you could feel a loss of "power" specially when going uphill.
clivey is offline   Reply With Quote Quick reply to this message
Old 11-23-2008, 10:05 PM   #6 (permalink)
Off-set is measurement for face of wheel. Backspace is measurement for back of wheel.
Old 11-23-2008, 10:38 PM   #7 (permalink)
That's a good start for tire measurements, but when you get to a 31 you're gonna start having problems turning. To fit 33's on my trail rig I had to move the axle forward, go to a high steer solution, go to an aftermarket bumper and trim/clearance the fenders/firewall. And that doesn't include the wheel spacers I added when I went to 31's...
If you just add height without the rest, you are gonna you're gonna get silly tall and badly balanced.
Anyone wanna guess what it takes to put 35's under a Sammy without looking silly?
hehehe...
Old 11-23-2008, 10:56 PM   #8 (permalink)
Thanks for the enlightenment. The tire guy used "offset" when he described the rims I needed for the bigger tires so I ended up using the same term.
From which points on the wheel is backspace measured?
Old 11-23-2008, 11:01 PM   #9 (permalink)
Lay wheel face down, Place a strip of wood or metal over rim an measure from bolt pattern up to to object like picture below shows.
Old 11-23-2008, 11:01 PM   #10 (permalink)
hehehe...
Yeah there is more to lifting your rig then what i posted.
This what it took when i did 5" SPOA lift to clear 31's on my girlfriend's 88 Samurai Tin-Top.
All found at Rocky-Road.com
Suspension
5" Bolt-on SPOA w/ Hydro Shocks (keep factory height springs)
2nd Rear Brake Line (86-88)
Drivetrain
4.57 Complete Combo Gearing Package
Traction Bar Kit
T-case Complete Mega-mount kit
Birfield Joints
Steering
OTT Steering Stage 1 for 5 Lift
OTT Steering Stage 2 Upgrade For Flat Arm
Bolt-on Panhard Kit for SPOA
OME Steering Stabilizer Shock Kit
Cost about $3,100.00 w/o Shipping, Wheels & Tires an other accessories
